06-08 HONDA TRX450R INTAKE SYSTEM
September 3rd, 2008 by admin
P
NEW 06-08 HONDA TRX450R INTAKE SYSTEM NOW AVAILABLE
NE
 “The Ultimate Bolt on Power”
Fuel Customs has engineered a cutting edge intake system by incorporating the latest dyno proven techniques and innovative designs improving intake system efficiency raising the bar in ATV high performance!
Our exclusive tapered design enhances air flow velocity giving optimum power over the entire rpm range. Not only will Torque and H.P. increase, so will your throttle response. A unique design feature is our 8ply filter offering maximum protection with zero air flow loss compared to our competitor’s 4ply filters. ATV industry leading motor builders and pro racers will agree this true bolt on power intake system is a must for all you performance gurus!
When developing TRX450R intake systems we envisioned a complete system that offers everything you would expect from an intake system and more. We wanted it to fit all aspects of quad racing as you know it. Due to the limited space that the Honda TRX450R presents, most aftermarket intakes do not fit with aftermarket shocks, Fuel Customs intakes DO fit.  With our unique tapered design you are able to run the intake system with or without the factory box. From MX, to the muddy trails to the sand, this intake can handle it all.
INNOVATIVE TAPERED DESIGN
One thing that is common amongst most aftermarket intakes is they’re usually a straight tube with a consistent diameter. The flow that a straight diameter pipe presents is considerably different than one that is turned and tapered leading to a pulsing intake tract of an engine.
THE DYNAMICS CHANGE HUGLEY!
In every high performance engine build, there is a certain length intake needed to get the best performance at that particular engines running frequency. Finding that length with the (PROPER TAPER) before the bell of the carb is a fairy important step and one that has not escaped us here at Fuel Customs.
Key Benefits:
  • Unique tapered design to create velocity
  • Smooth carb transition
  • Improved throttle response
  • Increased hp & tq across the rpm range
  • 8ply filter for enhanced protection
  06-08  Honda TRX450R
“Ultimate Bolt on Power”
 Retail: 5.00
To Order @ www.fuelcustoms.com
Testimonials:
“When we build performance motors, we use the best components we can acquire. This helps us offer the most powerful, reliable motors on the market. The Fuel Customs Intake System is one of those components.”
-Allan Knowles, owner CT Racing
(Engine builders of Multi time, Score off Road Series Champions,
 24 hour Team Race Champions, Best in the Desert Series Champions, GNC and GNCC Series Champions)
“The Intake gets the response from your thumb to the dirt in a split second without hesitation. The best power for the dollar that I have paid for.”
-Charley Mcmanigal, Motocross Racer
Ready for Immediate Release.
If you have any questions please contact:
Garrett Torres
Fuel Customs
garrett@fuelcustoms.com
Office: (909) 594-6082
Mobile: (626) 392-1480
www.fuelcustoms.com
P
