2004 KAWASAKI PRAIRIE 700 4X4
January 1st, 2006 by admin
| 2004 PRAIRIE 700 4X4 SPORT UTILITY ATV Prairie 700 4×4 receives infusion of V Force power |
Kawasaki Motors Corp., U.S.A., announced that the Prairie 650 4×4 sport utility all-terrain vehicle (ATV) is being replaced for 2004 by the new Prairie 700 4×4 ATV.
As the new king of the big-bore 4×4 segment, the Prairie 700 4×4 boasts more engine displacement and more torque, and for those who haven’t guessed yet, it has more than just a little influence from Kawasaki’s ultra-high-performance KFX700 V Force sport ATV.
The Prairie 700 4×4 retains the main features of its predecessor, such as selectable four-wheel drive with variable locking differential control, the Kawasaki Automatic Power-Drive System (KAPS), dual front disc brakes and the Kawasaki-exclusive sealed rear braking system. The new V-twin four-stroke engine, however, borrows many of its parts from the recently introduced KFX700 V Force sport ATV.
Jim Williams, ATV product manager for Kawasaki, said engineers developed the original Prairie 650 V-twin engine with the knowledge that they would make continual refinements in power and overall performance, essentially creating a powerplant that would be utilized in several different models. The ultra-high-performance KFX700 V Force was another step up in performance, and now those upgrades are being applied to the new Prairie 700 4×4 sport utility ATV.
“The rule for four-wheel drive ATV enthusiasts is that you can never have too much torque,” said Williams. “So, we took many of the internals from the KFX700 V Force and put them into the Prairie 700 4×4, then tuned it for four-wheel drive applications.”
In addition to the V Force-influenced powerplant, the Prairie 700 4×4 features redesigned cargo racks, front bumper and grille. And for hunting enthusiasts, the Prairie 700 4×4 is now available in REALTREE® Hardwoods® Green HD™ camouflage as well as Aztec Red and traditional Hunter Green. With its unique high-definition pattern, the Hardwoods Green replaces the Advantage Classic® camouflage offered on the Prairie 650.
The liquid-cooled, four-stroke, 90-degree V-twin engine in the Prairie 700 4×4 displaces 697cc—64 more than the Prairie 650. The engine cases, cylinders, cylinder heads, dual Keihin CVKR-D32 carburetors, and bore and stroke are the same as the KFX700 V Force.
Power from the V-twin engine is transferred through KAPS, Kawasaki’s continuously variable transmission, to dependable shaft drive. Plus, with the flip of a switch, the Prairie 700 4×4 rider can select two- or four-wheel drive operation.
The Prairie 700 4×4 also features Kawasaki’s exclusive Variable Front Differential Control. When operating in four-wheel drive, the rider can pull a small lever on the left handlebar to vary the amount of differential slip. This helps the rider control the power delivered to each front wheel, so the wheel with traction will always receive some torque, a decided advantage when encountering deep mud or slippery uphill trails. The Prairie 700 4×4 braking system has stopping power equal to its enhanced V-twin engine, with dual front disc brakes and the Kawasaki-exclusive oil-bathed, multi-disc rear brake system to give the rider maximum control.
To assist the operator when crawling over rocky terrain or descending steep hills, the Prairie 700 4×4 also features Kawasaki Engine Brake Control (K-EBC™). K-EBC electronically monitors ground speed and uses the engine’s compression to help slow the ATV.
To provide a smooth, comfortable ride becoming of a Kawasaki, the Prairie 700 4×4 rides on MacPherson strut front suspension with 6.7 inches of travel and a rear aluminum swingarm with 7.2 inches of travel. Other Prairie 700 4×4 comforts include a large saddle and adjustable footpegs atop full-sized floorboards. Plus, the new cargo racks can carry 264 pounds.
Even with an increase in engine displacement, torque and total power output, the Prairie 700 4×4 has a 602-pound dry weight—two pounds less than its predecessor. And like the previous model, the V-twin is shorter than most single-cylinder engines so it has a lower center of gravity for added stability.
Features and Benefits:
90-degree, 697cc four-stroke engine shares many of the design features of the KFX700 V Force sport ATV, giving it class-leading performance and the torque four-wheel drive enthusiasts demand. Kawasaki Automatic-Power Drive System has high and low forward gears plus reverse, so no shifting is required. Selectable four-wheel drive gives the rider the ability to choose two-wheel or four-wheel drive. The limited-slip front differential permits easy turning, yet the rider can utilize the Variable Front Differential Control to “lock” the front wheels for maximum traction on difficult terrain. Electronically controlled Kawasaki Engine Brake Control helps to slow the ATV when traversing steep downhills. Dual-piston caliper front disc brakes provide aggressive stopping power and are complemented by the industry’s first sealed, oil-bathed, multi-disc rear braking system. MacPherson strut front suspension gives a smooth, comfortable ride. Aluminum swingarm is sturdy and lightweight, and the shock features adjustable spring preload. A fully digital instrument panel provides the rider important information at a glance. All-new bumper, front grille and cargo racks are rugged and practical—the racks can carry 264 pounds. Optional REALTREE® Hardwoods® Green HD™ camouflage has a unique pattern to help the Prairie 700 4×4 “blend in” with the natural green surrounding of a favorite hunting blind. Towing hitch comes standard. 2004 KAWASAKI
PRAIRIE® 700 4X4 ATV SPECIFICATIONS
Engine: Liquid-cooled, 90-degree, 4-stroke V-twin Valve system: SOHC, four valves Displacement: 697cc Starting system: Electric with recoil back-up Bore x stroke: 82 x 66mm Compression: ratio 9.9:1 Carburetion: (2) Keihin CVKR-D32 Ignition: DC-CDI Transmission: Dual-range CVT plus reverse with K-EBC™ (Kawasaki Engine Brake Control) Final drive: 2×4/4×4 shaft Frame: Double cradle, tubular steel Suspension: Front/wheel travel MacPherson/6.7 in. Rear/wheel travel Aluminum swingarm and single shock/7.2 in. Tires: Front AT25 x 8-12 Rear AT25 x 10-12 Brakes: Front (2) Dual-piston disc Rear Sealed oil-bathed multi-disc Overall length: 86.2 in. Overall width: 46.5 in. Wheelbase: 50.8 in. Ground clearance: (at center of chassis/at rear axle) 9.5/7.6 in. Seat height: 34.3 in. Lighting: Headlights (2) Halogen 12V, 45W Rack capacity: Total 264 lbs. Towing capacity: 1,250 lbs. Dry weight: 602 lbs. Fuel capacity: 4.5 gal. Instruments: Speedometer, odometer, dual trip meters, clock, hour meter, fuel gauge, 2×4/4×4 indicator light, neutral indicator light, reverse indicator light, low fuel warning light, low oil warning light Colors: Aztec Red, REALTREE® Hardwoods® Green HD™ camouflage, Hunter Green
