2007 Kawasaki NRA Outdoors Brute Force 750 4x4i
Limited edition model features more camouflage than any other ATV
This official licensed NRA ATV is a hunter’s dream and the perfect addition to every sportsman’s garage. The Kawasaki NRA OUTDOORS Brute Force 750 4x4i
special edition features the Advantage® MAX-I™ HD™ camouflage pattern. In addition
to the bodywork, extra camouflage on the NRA OUTDOORS model covers the front guard, front and rear racks and all four wheels making it a perfect compliment to the hunting lifestyle.
Based on the standard Brute Force 750 4x4i, the NRA OUTDOORS Brute Force 750 4x4i is the most powerful, high-performance model in its class, offering a superior balance of rider comfort and convenience features. It’s powered by the largest V-twin engine on market, and it utilizes a fully independent (IRS) rear suspension system.
The NRA OUTDOORS Brute Force 750 4x4i is powered by Kawasaki’s
revolutionary 90-degree, four-stroke V-twin engine. Displacing 749cc, it features Electrofusion-plated aluminum cylinders, a reverse-facing air intake, 34mm downdraft carburetors, straight intake tracts, and four valves per cylinder. It also features a highefficiency radiator mounted high in the chassis where it is best protected from mud and debris.
The NRA OUTDOORS Brute Force 750 4x4i transfers power from its V-twin engine to the wheels through a continuously variable transmission (CVT) featuring high and low range, plus reverse, and by pressing a button on the handlebar, the rider can also select two- or four-wheel-drive operation. In four-wheel-drive mode, the Brute Force utilizes a limited-slip front differential, which eases steering effort under most riding conditions. The rider can also engage the Variable Front Differential Control to deliver torque equally to the right and left front wheels for maximum traction.
The front drive shafts of the Brute Force feature ATV Cardan joints – an industry first. Similar to U-joints, Cardan joints help absorb torque fluctuations to the drive shaft, and its lightweight design helps to reduce vibration.
The rear final gear case and sealed rear braking system have been designed in conjunction with the IRS. Smaller and more compact, the gear case is extremely rugged and efficient.
Dual front discs and Kawasaki’s highly acclaimed sealed rear braking system provide maximum stopping power. The rear braking system’s internal components are completely sealed to protect them from mud, dust and debris, and its compact size provides for more ground clearance than a conventional rear disc brake system. To
assist with braking, the engine features the Kawasaki Engine Brake Control, which helps to slow the ATV when traversing steep downhills.
The NRA OUTDOORS Brute Force 750 4x4i gives the rider 10.6 inches of ground clearance and it rides on 12-inch wheels shod with tires that feature aggressive tread blocks. Rider position is upright and comfortable, enhancing the rider’s ability to scan the horizon, and the automotive-style instrument panel is positioned vertically to make it easy to read.
The NRA OUTDOORS Brute Force 750 4x4i features full-sized floorboards and a large, comfortable seat. To enhance chassis balance, the large 5.4-gallon fuel tank is positioned beneath the seat. Other features include the ATV industry’s first four-bulb
headlights, storage compartments located in the left and right front fenders, the ability to carry a combined weight of 264 pounds on its cargo racks, and a tow rating of 1,250 pounds.
Authentic Kawasaki Accessories for the 2007 NRA OUTDOORS Brute Force 750 4x4i are available through Kawasaki dealers or they can be purchased on the Internet at www.kawasaki.com.
As with all off-highway vehicle recreation, Kawasaki encourages ATV riders to ride responsibly and to respect the environment. Kawasaki will pay first-time buyers of a new Kawasaki ATV 0 for completing an ATV rider safety course conducted by the ATV Safety Institute (ASI). Interested consumers can call ASI toll-free at 800-887-2887.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasaki motorcycles, ATVs, personal watercraft and utility vehicles through a network of more than 1,500 independent retailers, with an additional 7,700 retailers specializing in power
products and general purpose engines. KMC and its affiliates employ nearly 2,400 people in the United States, with 400 of them located at the Irvine, California headquarters.
™ Kawasaki’s tagline, “Let the good times roll. ”, is recognized worldwide and the brand has become synonymous with powerful, stylish motorcycles for over four decades. Information about Kawasaki’s complete line of recreational products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com.
- 90-degree V-twin engine displaces 749cc – the largest, most powerful engine in its class
- Straight intake tracts and 34mm downdraft carburetors enhance power delivery throughout the rpm range Brakes
- Air for the continuously variable transmission (CVT) and airbox enter from a reverse-facing snorkel located beneath the handlebars to help protect against water and mud
- Access to the airbox is simplified by removing only one cover
- Radiator is compact and placed high in the chassis for better protection against mud and debris
- Aluminum cylinders are Electrofusion-plated for light weight, long wear and excellent heat dispersion
- Rare-earth magnets in the generator are highly efficient and compact, contributing to reduced engine width
- Engine can be started in any gear when the rear brake is applied
Transmission/Selectable Four-wheel-drive
- CVT transmission features high and low ranges, plus reverse
- Rider can select two- or four-wheel-drive operation by pressing a button located on the handlebar
- Limited-slip front differential reduces steering effort under normal four-wheel drive operation, while Variable Front Differential Control to permits rider to distribute torque equally to left and right front wheels for maximum traction
- Cardan joints on drive shafts absorb torque fluctuations and reduce vibration
Chassis
- Double-cradle frame is made of sturdy, tubular steel
- Chassis provides 10.6 inches of ground clearance
- Dual A-arm front suspension feature adjustable shocks and 6.7 inches of travel
- Independent rear suspension provides the best balance of rider comfort and handling at low to medium speeds, and provides 7.9 inches of travel
- Upper and lower front A-arms and lower rear A-arms utilize a combination of needle bearings and ball joints for smooth suspension action, high stability and excellent rider comfort
Brakes
- Dual front disc brakes with two-piston calipers and Kawasaki’s sealed, oil-bathed, multi-disc rear brake system provide maximum stopping power
- The engine features electronic Kawasaki Engine Brake Control, which helps to slow the ATV when traversing steep downhills
Bodywork/Ergonomics
- Advantage® MAX-I™ HD™ camouflage on bodywork, racks and wheels
- Thermo-Plastic Olefin bodywork is scratch resistant
- Convenient storage compartments are located in the right and left front fenders
- Four-bulb 40-watt headlights provide maximum lighting power for nighttime rides
- Rider position is upright for enhanced comfort
- Automotive-style instruments are mounted upright in conjunction with the rider position
- Engine:Liquid-cooled, 90-degree, four-stroke V-twin
- Displacement:749cc
- Bore x stroke:85 x 66mm
- Compression ratio:8.8:1
- Carburetion:(2) Keihin CVKR-34
- Ignition:Digital DC-CDI
- Transmission:Continuously variable belt-drive transmission with high and lowrange, plus reverse, and Kawasaki Engine Brake Control
- Final drive:Selectable four-wheel drive with Variable Front Differential Control, shaft
- Frame:Double-cradle, tubular steel
- Suspension front / wheel travel:Dual A-arm / 6.7 in.
- Suspension rear / wheel travel:Fully Independent, dual A-arm / 7.9 in.
- Front tire:AT25x8-12
- Rear tire:AT25x10-12
- Front brakes / rear brake:Dual hydraulic discs with 2-piston calipers / Sealed, oil-bathed, multi-disc
- Overall length:86.3 in.
- Overall width:46.3 in.
- Wheelbase:50.5 in.
- Ground clearance:10.6 in.
- Seat height:36.8 in.
- Lighting:(4) 40W headlights, 5W taillight, 21W stoplight
- Rack capacity, front / rear:88 / 176 lbs.
- Towing capacity:1,250 lbs.
- Fuel capacity:5.4 gal.
- Dry weight:604.2 lbs.
- Instruments:Speedometer, odometer, dual trip meters, clock, hour meter, fuel gauge, 2×4/4×4 indicator, neutral indicator, reverse indicator, low fuel warning light, low oil warning light
- Color choices:Advantage® MAX-I™ HD™ camouflage
- MSRP:TBD
