2009 Can-Am Outlander MAX 800R EFI
January 1st, 2006 by admin
P
While the Renegade series from Can-Am combine utility-style engines with sport-ATV handling, the Outlanders exist for those who want a quad that works as hard as they do. Sharing an engine with the top of the line Renegade, the Outlander is built around a more traditional utility chassis and a longer frame designed to support the weight of two riders.
Model Type
 Utility
BASE MSRP(US)
 ,799.00
Warranty
 6 months
Engine:
Engine Type
 V Twin
Cylinders
Engine Stroke
 4-Stroke
Valve Configuration
 SOHC
Displacement (cc/ci)
 799.9 / 48.8
Carburetion Type
 Fuel Injected
Transmission:
Transmission Type
 Continuously Variable (CVT)
Primary Drive (Front Wheel)
 Shaft
Reverse
 Yes
Wheels & Tires:
Front Tire (Full Spec)
 Carlisle 26 X 8-12
Rear Tire (Full Spec)
 Carlisle 26 X 10-12
Brakes:
Front Brake Type
 In-Board Dual Disc
Rear Brake Type
 Hydraulic Disc
Technical Specifications:
Wheelbase (in/mm)
 59 / 1499
Dry Weight (lbs/kg)
 713 / 323.4
Fuel Capacity (gal/l)
 5.3 / 20
Seats:
Seat Height (in/mm)
 34.5 / 877
Number Of Seats
Drive Line:
Driveline Type
 Selectable 4X2 / 4X4
Number Of Driveline Modes
Limited Slip Differential
 Standard
Differential Lock
 Standard
Storage:
Rear Rack
 Standard
Front Rack
 Standard
Lights:
Halogen Headlight (s)
 Standard
P
