2009 Suzuki King Quad 450 Axi Camo
January 1st, 2006 by admin
No Suzuki Kingquad would be complete with out a camouflage option. All of the award winning features of the KingQuad 750, Suzuki’s flagship ATV, but in a package that offers the best value in its class.
Suzuki brings all the valuable features to the class: styling, engine performance, electronic fuel injection, independent rear suspension, locking front differential and a host of other valuable features mean the KingQuad 450 leads its class in value and performance.
The special version KingQuad 450 featuring REALTREE HARDWOODS HD ENHANCED camouflage bodywork – Exclusive to Suzuki.
The KingQuad lineage is important to Suzuki and it is important that the new KingQuad 450 builds on the storied name. When the original KingQuad was introduced to the world in 1991, it was a revolutionary ATV. Revolutionary is a strong word but history has judged it to be true. At a time when solid rear axles were commonplace, Suzuki brought independent rear suspension and a locking front differential to the ATV world. At a time when a five speed transmission was the lap of luxury, KingQuad owners got the most innovative transmission on the market. High, low and super-low ranges gave the original KingQuad owners 15 drive options.
The original KingQuad delivered utility performance with comfortable trail manners. The original KingQuad established Suzuki in the ATV Market. The KingQuad 750 solidified Suzuki’s legacy to the industry. Now the KingQuad 450 sets the new standard for a whole class of ATVs.
FEATURES
Key Features
- Special version KingQuad 450 featuring Realtree Hardwoods HD Enhanced camouflage bodywork – Exclusive to Suzuki
Engine Features
- Powerful 454cc, SOHC, single-cylinder, liquid-cooled engine designed for a wide powerband and strong performance
- Uses a cylinder canted forward for lower center of gravity, reduced engine height and lower seat height
- Compact 4-valve cylinder head with large intake valves and straight intake ports for increased efficiency
- Sportbike-derived chain-and-gear camshaft drive system allows a short/narrow cylinder head design and reduced overall engine height
- Suzuki fuel injection system featuring high-performance motorcycle technology provides excellent throttle response, fuel efficiency and quick engine starts under all operating conditions
- QuadMatic™ CVT-type automatic transmission designed for maximum versatility and convenience – fender-mounted gate-type shifter operation for high/low forward ranges, plus neutral and reverse
- Advanced engine brake system minimizes free-wheeling to reduce downhill speed
- Electric 2WD, 4WD and differential-lock 4WD – convenient handlebar-mounted push-button controls allow the rider to easily select the right setting for any traction condition
- Compact torque-sensing limited-slip front differential offers more powerful traction plus light steering effort, including a differential-lock system that provides serious four wheel-drive traction.
- High capacity aluminum radiator with large diameter cooling fan for stable engine operating temperature
- Spin-on-type oil filter – simplifies oil change maintenance Chassis Features
- Independent double A-arm front suspension with 7.1 inches of wheel travel – includes large diameter shock absorbers with 5-way spring preload adjustment
- Fully independent, I-beam rear suspension with long suspension travel (7.9 inches) – includes 5-way preload adjustable shock absorbers and large diameter rear stabilizer sway-bar
- Polyethylene skid plate provides front-to-rear under carriage protection with minimal resistance over rocks and rough terrain. Durable plastic guards protect the front and rear half shafts
- Sealed, multi-plate rear brake system – clutch-type design provides high durability, reduced unsprung weight and low-maintenance
- 25-inch Maxxis tires mounted on lightweight aluminum-alloy wheels
- Full floorboards with aggressively serrated footpegs and mud drain holes
Special
- Minimum Age: 16 Years Old
Utility/Convenience Features
- Distinctively-styled 30W multi-reflector halogen headlights, and compact 5/21W tail light and brake light
- High output magneto generator system and large 18-amp maintenance-free battery provides extra power
- Large 4.6 gallon fuel tank positioned for a low center-of-gravity – includes vacuum-operated petcock, ratchet-style fuel cap and bar-type fuel gauge
- Rugged steel-tube racks with wrinkle paint finish for increased durability and scratch resistance
- Large 2.8 liter water resistant front storage compartment – includes new easy-to-open/close screw-on cap Specifications
- Specifications KingQuad 450AXi 4×4 Camo
- Model Number LTA450XCK9
- Type Utility Sport
- Warranty 12 month limited warranty.
- Suggested Retail 99
- SEP 8
- Engine 4-stroke, liquid-cooled, OHC
- Bore & Stroke 84.0 mm (3.307 in) x 82.0 mm (3.228 in)
- Compression Ratio 10.0 : 1
- Fuel System Fuel injection
- Lubrication Wet sump
- Ignition Electronic ignition (CDI)
- Starter Electric and recoil starter
- Transmission Automatic variable ratio (V-belt)
- Final Drive Shaft drive
- Overall Length 2115 mm (83.3 in)
- Overall Width 1210 mm (47.6 in)
- Overall Height 1215 mm (47.8 in)
- Seat Height 860 mm (33.9 in)
- Ground Clearance 260 mm (10.2 in)
- Wheelbase 1280 mm (50.4 in)
- Dry Weight 305 kg (672 lbs)
- Suspension Front Independent, double wishbone, coil spring, oil damped
- Suspension Rear Independent, double wishbone, coil spring, oil damped
- Brakes Front Disc brake, twin
- Brakes Rear Sealed oil-bathed multi-disc
- Tires Front AT25 × 8-12, tubeless
- Tires Rear AT25 × 8-12, tubeless
- Fuel Tank Capacity 17.5 L (4.6/3.8 US/Imp gal)
- Color Realtree Hardwoods HD Enhanced
* Specifications and features are subject to change
