2009 Suzuki Kingquad 400 AS
January 1st, 2006 by admin
P
There was a time in the recent past when 400cc represented the very largest utility machine engine displacement.  These days, the 400s represent the middleweight utility class and Suzuki has their bases covered with the Kingquad 400 4×4 Automatic.
There’s no limit to how tough and versatile a middleweight ATV can be. For proof, check out the KingQuad 400 4×4 Automatic. The KingQuad 400 lets you quickly and conveniently select two- or four-wheel drive operation. And whether you have a long day of work ahead or a long trail in front of you, you’ll appreciate your KingQuad’s load of technically advanced features.
Features
New Features
  • Gate-type shift lever is mounted on the left side providing simple and precise shifting in various riding conditions
Key Features
  • Angular and aggressive bodywork featuring high clearance fenders, the distinctive KingQuad headlights and grill, a T-shaped seat, and highlighted by a large diameter steel tube bumper
  • Large 4.2-gallon fuel tank for long riding range and improved rider comfort
  • Large 190mm diameter front disc brakes combined with front brake calipers featuring 34mm-diameter pistons for improved braking performance
  • 25-inch Maxxis tires featuring an aggressive dual stage tread pattern for consistent traction and a quiet ride are mounted on durable steel wheels
  • Semi-Automatic version of the KingQuad400 – combines comfort and practical features with a sporty feel and an aggressive look – the best features and value in the mid-size class
Engine Features
  • Dependable 376cc single-cylinder, 4-valve, 4-stroke engine is tuned for high-torque output and quick acceleration, and uses Suzuki’s well-proven SACS air-oil cooling system. Gear-driven balancer shaft reduces vibration
  • Keihin™ CVK32 carburetor provides smooth throttle response and high fuel efficiency – throttle pulley system designed for light throttle lever operation
  • Five-speed transmission with automatic clutch, high/low range and reverse – subtransmission and reverse controlled by a single automotive-style, fuel tank-mounted drive selection lever
  • Choose 2WD or 4WD operation with convenient handlebar-mounted control lever
  • Torque-sensing limited-slip front differential provides maximum traction and light steering in tight turns
  • Electric and recoil starting with “in gear” starting capability – engine will start in any transmission setting by pulling the hand brake lever and pressing the starter button
Chassis Features
  • Styled for a big, strong appearance with high radius fenders, a rugged-style grill and large front bumper designed for easy winch installation
  • Compact instrument display including speedometer, odometer, tripmeter, and indicator lights for neutral, reverse and oil temperature
  • 12V/120W electrical outlet mounted in left front fender – standard automotive-style outlet fits a wide range of electrical accessories
  • Twin 35/35W fender-mounted multi-reflector headlights, plus large 5/21W combination taillight and brake light as standard equipment
  • Durable steel frame made of large diameter, thin-wall tubing for maximum strength and minimal weight
  • Lightweight polyethylene skid plate and bumper guard provide maximum protection with minimal resistance over rocks and other obstacles
  • Independent double A-arm front suspension with class-leading 6.7 in. of wheel travel for a comfortable ride on all types of terrain
  • Swingarm-style rear suspension with oil-damped shock absorbers provide 6.7 in. of wheel travel and 9.3 in. of ground clearance
  • High-capacity racks and towing capacity, plus 4.0 liter storage box now located and protected under the seat
Special
  • Minimum Age: 16 years old
Specifications
  • Specifications KingQuad 400 AS
  • Model Number KLTA400FK9
  • Type Utility Sport
  • Warranty 12 month limited warranty.
  • Suggested Retail 99
  • SEP 6
  • Engine 4-stroke, air-cooled with SACS, OHC
  • Bore & Stroke 82.0 mm (3.228 in) x 71.2 mm (2.803 in)
  • Compression Ratio 9.0 : 1
  • Fuel System KEIHIN CVK32, single
  • Lubrication Wet sump
  • Ignition Electronic ignition (CDI)
  • Starter Electric starter
  • Transmission Automatic variable ratio (V-belt)
  • Final Drive Shaft drive
  • Overall Length 2060 mm (81.1 in)
  • Overall Width 1145 mm (45.1 in)
  • Overall Height 1220 mm (48.0 in)
  • Seat Height 840 mm (33.1 in)
  • Ground Clearance 250 mm (9.8 in)
  • Wheelbase 1270 mm (50.0 in)
  • Dry Weight 285 kg (628 lbs)
  • Suspension Front Independent, double wishbone, coil spring, oil damped
  • Suspension Rear Swingarm type, coil spring, oil damped
  • Brakes Front Disc brake, twin
  • Brakes Rear Drum brake
  • Tires Front AT25 × 8-12, tubeless
  • Tires Rear AT25 × 8-12, tubeless
  • Fuel Tank Capacity 16.0 L (4.2/3.5US/Imp gal) – Including Reserve
  • Color Red, Green
* Specifications and features are subject to change
P
