2009 Suzuki Kingquad 400 AS Camo Review
January 1st, 2006 by admin
P
For 2009, Suzuki offers outdoorsmen and women a camouflage option for the versatile middleweight Kingquad 400 AS.
When you’re planning your next hunting or fishing trip, plan on taking along the ideal back woods companion: the KingQuad 400 Camouflage Edition 4×4. It features REALTREE HARDWOODS HD® ENHANCED  pattern that incorporates the latest advancements in camouflage artwork.
The KingQuad 400 Camouflage Edition: it’s the outdoor companion you’ve been hunting for.
Features
Key Features
  • Special version KingQuad 400 featuring Realtree Hardwoods HD Enhanced camouflage bodywork
  • Mid-size sport-utility model that combines comfort and practical features with a sporty feel and an aggressive look – the best features and value in the class
  • Aggressive, angular bodywork features high-clearance fenders, the distinctive KingQuad headlights and grill, a T-shaped seat, and a large diameter steel tube bumper
  • Large 4.2-gallon fuel tank for long riding range and improved rider comfort. Fuel gauge is mounted atop tank
  • 25-inch Maxxis tires featuring aggressive dual-stage tread patterns for consistent traction and a quiet ride are mounted on durable steel wheels
  • Gate-type shift lever is mounted on the left side and provides simple and precise shifting in various riding conditions
Engine Features
  • Dependable 376cc single-cylinder 4-valve, 4-stroke engine is tuned for high-torque output and quick acceleration, and uses Suzuki’s well-proven SACS air-oil cooling system. Gear-driven balancer shaft reduces vibration
  • Keihin™ CVK32 carburetor provides smooth throttle response and high fuel efficiency – includes throttle pulley system designed for light throttle lever operation
  • V-belt CVT QuadMatic™ transmission with high/low range and reverse – all controlled by a single automotive-style, tank-mounted gear selection lever
  • Choose 2WD or 4WD operation with convenient handlebar-mounted control lever
  • Torque-sensing limited-slip front differential provides maximum traction and light steering in tight turns
  • Advanced engine brake system minimizes free-wheeling to reduce downhill speed
  • Electric and recoil starting with “in gear” starting capability – engine will start in any transmission setting by pulling the hand brake lever while pressing the starter button
  • CDI ignition and powerful 220 watt charging system with maintenance-free battery
Chassis Features
  • Styled for a big, strong appearance with high radius fenders, a rugged-style grill and large front bumper designed for easy winch installation
  • Compact instrument display includes speedometer, odometer, tripmeter, and indicator lights for neutral, reverse and oil temperature
  • 12V/120W electrical outlet mounted in left front fender – standard automotive-style outlet fits a wide range of electrical accessories
  • Twin 35/35W fender-mounted multi-reflector headlights, plus large 5/21W combination taillight and brake light as standard equipment
  • Durable steel frame made of large diameter, thin-wall tubing for maximum strength and minimal weight
  • Lightweight polyethylene skid plate and bumper guard provide maximum protection with minimal resistance over rocks and other obstacles
  • Independent double A-arm front suspension with class-leading 6.7 in. of wheel travel for a comfortable ride on all types of terrain
  • Swingarm-style rear suspension with oil-damped shock absorbers provide 6.7 in. of wheel travel and 9.8 in. of ground clearance
  • High-capacity front and rear cargo racks and towing capacity, plus 4.0 liter storage box now located and protected under the seat
Special
  • Minimum Age: 16 years old
Specifications
  • Specifications KingQuad 400 AS Camo
  • Model Number KLTA400FCK9
  • Type Utility Sport
  • Warranty 12 month limited warranty.
  • Suggested Retail 99
  • SEP 6
  • Engine 4-stroke, air-cooled with SACS, OHC
  • Bore & Stroke 82.0 mm (3.228 in) x 71.2 mm (2.803 in)
  • Compression Ratio 9.0 : 1
  • Fuel System KEIHIN CVK32, single
  • Lubrication Wet sump
  • Ignition Electronic ignition (CDI)
  • Starter Electric starter
  • Transmission Automatic variable ratio (V-belt)
  • Final Drive Shaft drive
  • Overall Length 2060 mm (81.1 in)
  • Overall Width 1145 mm (45.1 in)
  • Overall Height 1220 mm (48.0 in)
  • Seat Height 840 mm (33.1 in)
  • Ground Clearance 250 mm (9.8 in)
  • Wheelbase 1270 mm (50.0 in)
  • Dry Weight 285 kg (628 lbs)
  • Suspension Front Independent, double wishbone, coil spring, oil damped
  • Suspension Rear Swingarm type, coil spring, oil damped
  • Brakes Front Disc brake, twin
  • Brakes Rear Drum brake
  • Tires Front AT25 × 8-12, tubeless
  • Tires Rear AT25 × 8-12, tubeless
  • Fuel Tank Capacity 16.0 L (4.2/3.5US/Imp gal) – Including Reserve
  • Color Realtree Hardwoods HD Enhanced
* Specifications and features are subject to change
P
