2009 Suzuki Kingquad 750 AXi Camo Review
January 1st, 2006 by admin
If red or green doesn’t tickle your fancy, Suzuki doesn’t want that to stop you from experiencing their flagship utility model, the Kingquad 750 AXi. All new for 2009, the king of Kingquads gets the camouflage treatment for a small up charge.
The Suzuki KingQuad 750 is an ATV like no other. Just like when it built the first four-wheeler, Suzuki bestowed upon its newest ATV both functional and sporting features. This new KingQuad 750 is designed to be not only the best all-around sport/utility ATV currently made, but the best QuadRunner ATV Suzuki has ever manufactured.
The KingQuad 750 is powered by a single-cylinder liquid-cooled DOHC engine with a bore-and-stroke of 104mm x 85mm – displacing 722cc. The big bore helps this four-stroke develop abundant torque, especially in the low- to mid-rpm range. The fuel-air mixture is delivered efficiently via Suzuki’s own fuel-injection system, featuring technology tested through years of development in high-performance motorcycles. Advantages of the KingQuad 750′s fuel injection system include reduced fuel consumption overall. Also, there are no choke operations or carburetor settings to consider. Electronic fuel injection provides better throttle response and smoother engine power than a mechanical carburetor. Finally, the KingQuad 750 has the ultimate power-delivery drivetrain and transmission with three drive modes available: two-wheel drive, four-wheel drive, and front differential-locked four-wheel drive.
Built around an all-new high-tensile steel frame, the KingQuad’s suspension is fully independent. It’s designed to maintain the necessary rigidity of a hard-working utility ATV as well as the light weight of an easily manageable recreational four-wheeler. New front and rear brake systems help smoothly slow the KingQuad 750 — the front end features hydraulic brakes with 200mm discs at each wheel. The KingQuad 750 rides on newly designed, 25-inch, bias-ply Dunlop tires mounted on pressed-aluminum-alloy wheels.
With its high-arched fenders and sharp headlights, the Suzuki KingQuad 750 combines sporty appeal with utility strength.
Features
Key Features
- Powerful KingQuad engine features a large 104mm bore for a displacement of 722cc providing maximum performance and throttle response
- Ultra-efficient air filter features both paper and foam elements for optimum air filter performance
Engine Features
- Cylinder canted forward 48 degrees for lower center of gravity, reduced engine height and lower seat height, and is rubber mounted with two balancer shafts for smooth performance
- Compact 4-valve cylinder head with large 36mm intake valves and straight intake ports for increased cylinder charging efficiency – includes lightweight magnesium valve cover
- Semi-gear driven valve system minimizes cam sprocket size allowing a short/narrow cylinder head design and reduced overall engine height
- Plasma-spray cylinder coating (SPSC) allows lightweight cylinder construction without a sleeve for improved resistance to heat and friction
- Suzuki fuel injection system provides excellent throttle response, fuel efficiency and quick engine starts
- QuadMatic™ CVT-type automatic transmission designed for maximum versatility and convenience – fender-mounted gate-type shifter operation for high/low forward ranges, plus neutral and reverse
- Advanced engine brake system minimizes free-wheeling to reduce downhill speed
- Electric 2WD, 4WD and differential-lock 4WD – convenient handlebar-mounted push-button controls allow the rider to easily select the right setting for any traction condition
Chassis Features
- Comfortable T-shaped seat with tapered design for rider mobility, plus thick padding for support
- Independent double A-arm front suspension with 7.1 inches of wheel travel – includes large diameter shock absorbers with 5-way spring preload adjustment
- Fully independent, I-beam rear suspension with long suspension travel (7.9 inches) – includes 5-way preload adjustable shock absorbers and large diameter rear sway-bar
- Large, 200mm diameter front disc brakes with single-piston calipers designed for strong, reliable braking performance
- Sealed, multi-plate rear brake system provides high durability, reduced unsprung weight and low-maintenance
- Pressed-aluminum wheels for reduced unsprung weight
- Polyethylene skid plate provides front-to-rear under carriage protection with minimal resistance over rocks and rough terrain
Special
- Minimum Age: 16 Years Old
Utility/Convenience Features
- Easy-to-read LCD instrument display – includes speedometer (mile/km selectable), odometer, twin-trip meters, hour meter, clock, fuel gauge, drive range (H,L,N,R) and drive mode (4WD, 4WD lock) – LED indicators for neutral, reverse, 4WD lock
- Distinctively-styled 30W multi-reflector halogen headlights, and compact 5/21W tail light and brake light – additional 40W multi-reflector, handlebar-mounted auxiliary light
- Large 4.6 gallon fuel tank positioned below seat for a low center-of-gravity – includes vacuum-operated petcock, ratchet-style fuel cap and convenient bar-type fuel gauge
- Rugged steel-tube racks with attractive, high-quality wrinkle paint finish
Specifications
- Specifications KingQuad 750AXi 4×4 Camo
- Model Number LTA750XCK9
- Type Utility Sport
- Warranty 12 month limited warranty.
- Suggested Retail 99
- SEP 6
- Engine 4-stroke, liquid-cooled, DOHC
- Bore & Stroke 104.0 mm (4.094 in) x 85.0 mm (3.346 in)
- Compression Ratio 10.0 : 1
- Fuel System Fuel injection
- Lubrication Wet sump
- Ignition Electronic ignition (CDI)
- Starter Electric and recoil starter
- Transmission Automatic variable ratio (V-belt)
- Final Drive Shaft drive
- Overall Length 2115 mm (83.3 in)
- Overall Width 1210 mm (47.6 in)
- Overall Height 1245 mm (49.0 in)
- Seat Height 880 mm (34.6 in)
- Ground Clearance 270 mm (10.6 in)
- Wheelbase 1280 mm (50.4 in)
- Dry Weight 302 kg (665 lbs)
- Suspension Front Independent, double wishbone, coil spring, oil damped
- Suspension Rear Independent, double wishbone, coil spring, oil damped
- Brakes Front Disc brake, twin
- Brakes Rear Sealed oil-bathed multi-disc
- Tires Front AT25 × 8-12, tubeless
- Tires Rear AT25 × 8-12, tubeless
- Fuel Tank Capacity 17.5 L (4.6/3.8 US/Imp gal)
- Color Realtree Hardwoods HD Enhanced
* Specifications and features are subject to change
