2009 Suzuki LT-Z250 Review
January 1st, 2006 by admin
P
2009 Suzuki LT-Z250
Bridging the gap between Suzuki’s LT-Z90 and LT-Z400 is the versatile yet easy-to-operate LT-Z250.  Looking a lot like the LT-Z400 and LT-R450, the Z250 represents the perfect stepping stone for riders looking for performance without having to worry about manual clutch operation.
Here is an awesome recreational sport four-wheeler with all the looks of a high-performance machine. Check out the QuadSport Z250′s race-inspired graphics, radical fenders and aggressive stance. It shouts sport performance – and has the power to make good on the promise.
As a sporting middleweight, the QuadSport Z250 combines agile responsiveness with a smooth and torquey powerband. Count in a wide range of features designed for comfort and convenience, and you’ve got the perfect choice for sport riders of all skill levels.
Key Features
  • Entry-level sport model loaded with style, performance and rider-friendly features
Engine Features
  • Single cylinder, 246cc, SOHC, air-cooled, 4-stroke engine designed to produce smooth, usable power over a wide rpm range
  • Cylinder head features screw/locknut valve adjustment system for simplified maintenance, plus a link-plate-type cam chain and automatic tensioner to reduce mechanical noise
  • Power is enhanced by a Mikuni BS 29mm carburetor mated to a large capacity airbox and a specially tuned exhaust system for a throaty sound
  • Convenient electric start system with Start-In-Gear feature
  • Electric start system and CDI ignition are powered by compact maintenance-free battery with 150 watt charging system
  • Five-speed transmission with automatic clutch includes an easy-to-use reverse gear system: place the transmission in neutral and turn the fender-mounted knob and depress the shift lever
  • Low-maintenance shaft final-drive system is simple and reliable
Chassis Features
  • Aggressive-styled bodywork includes high-clearance fenders, performance-inspired graphics and vertically mounted halogen headlight
  • Wide, T-shaped seat combines comfort with a functional shape that allows the rider to easily shift his/her weight
  • Single 40/40W, body-mounted halogen headlight provides and exciting look and bright illumination – large 5/21W taillight/brake light combination is standard
  • Rugged steel-tube frame with standard steel skid plate and tube-type bumper
  • Independent double A-arm front suspension with preload-adjustable oil-damped shock absorbers – provides 6.3 inches of wheel travel for a comfortable ride over all types of terrain
  • Swingarm-type rear suspension features single shock absorber with five preload adjustments and 6.7 inches of rear wheel travel, plus 9.1 inches of ground clearance
  • Large diameter front disc brakes with single-piston pin-slide calipers and single cable-operated rear drum brake
  • Lightweight aluminum wheels and rugged tires (F: 22×7-10, R: 20×10-9), for high style and traction under a wide variety of terrain conditions
  • Serrated-type footpegs for high grip and comfort with additional built-in mudguard protection
  • Convenient, 5-liter water-resistant storage box under the seat
  • Large 2.8 gallon fuel tank with vacuum-operated fuel petcock
Special
  • Minimum Age: 16 years old
Specifications
  • Specifications QuadSport Z250
  • Model Number LTZ250K9
  • Type Sport
  • Warranty 12-month limited warranty
  • Suggested Retail 99
  • SEP 6
  • Engine 4-stroke, air-cooled, OHC
  • Bore & Stroke 66.0 mm (2.598 in) x 72.0 mm (2.835 in)
  • Compression Ratio 9.2 : 1
  • Fuel System MIKUNI BSR29, single
  • Lubrication Wet sump
  • Ignition Electronic ignition (CDI)
  • Starter Electric
  • Transmission 5-forward and 1-reverse
  • Final Drive Shaft drive
  • Overall Length 1720 mm (67.7 in)
  • Overall Width 1070 mm (42.1 in)
  • Overall Height 1090 mm (42.9 in)
  • Seat Height 810 mm (31.9 in)
  • Ground Clearance 230 mm (9.1 in)
  • Wheelbase 1135 mm (44.7 in)
  • Dry Weight 177 kg (390 lbs)
  • Suspension Front Independent, double wishbone, coil spring, oil damped
  • Suspension Rear Swingarm type, coil spring, oil damped
  • Brakes Front Disc brake, twin
  • Brakes Rear Drum brake
  • Tires Front 0
  • Tires Rear 0
  • Fuel Tank Capacity 10.6 L (2.8/2.3 US/Imp gal) – Including Reserve
  • Color Yellow, White
* Specifications and features are subject to change
P
