2012 Polaris RANGER RZR 570 – Oh So Trail Capable
January 1st, 1970 by admin
P
rzr
A Detailed Look At Polaris’ Latest RZR
by Jason Giacchino
Since 2008, Polaris has introduced a new RANGER RZR model for each and every model year and despite the slow economy, 2012 is no exception.
The new RANGER RZR 570 is the domestic manufacturer’s entry designed to make the absolute most of the creature comforts of their flagship UTVs with the lower MSRP and fuel benefits of a smaller engine. Priced at ,999, the single-cylinder unit serves as a value-oriented trail machine that stays true to the RANGER RZR family promise of being the ultimate combination of power, suspension and agility.
At the heart of the RANGER RZR 570 is an all-new ProStar 570 single cylinder, DOHC, electronic fuel injected engine. The engine is the second in the ProStar family, made specifically for Side-by-Side vehicles, which also includes the ProStar 900 introduced last year in the RANGER RZR XP 900. The ProStar 570 has 650 watts of stator output and features a removable cargo bed floor and a wet sump for easy serviceability.
To complement the new engine, Polaris equipped the RANGER RZR 570 with a new transmission that was specifically built to optimize the power of the new ProStar engine. Its optimized gear geometry means more power to the ground, less driveline noise and lighter weight. The innovative design, first featured on the RANGER RZR XP 900, features a helical cut final drive with high torque capacity to maximize efficiency.
rzr-back
To tackle the rugged trail, the RANGER RZR 570 features an all-new, ultra smooth Independent Rear Suspension (IRS) with specifically designed geometry that provides 9.5-inches of travel in the rear. The front suspension features Dual A-Arms with 9-inches of suspension travel. Coupling the front and rear suspension with a 77-inch long wheelbase, pre-load adjustable ZF Sachs Shocks on all four corners and exclusive front and rear anti-sway bars that keep the chassis flat while cornering, gives the RANGER RZR 570 the ability to soak up anything the trail can throw in its way.
Since the launch of the RANGER RZR 800 in 2008, Polaris has been the only manufacturer to offer a trail-capable Side-by-Side. At 50 inches wide, the RANGER RZR 570 is the second trail-capable model in the family. Built with the patented design that places the engine behind the seat, the RANGER RZR 570 has a low center of gravity delivering agile, razor-sharp handling on the trail.
When the trail gets rough, the vehicle’s True All-Wheel Drive (AWD) system puts the 50-inch width to work in and out of corners. It’s the easiest-to-use and fastest responding on-demand system that automatically engages all four wheels when forward traction is needed and it reverts back to two-wheel drive automatically when AWD is no longer needed. The system provides easier steering, less wear and tear on driveline components, and maximum power when you need it most.
rzr
For comfort, RANGER RZR 570 also sports comfortable ergonomics with tilt steering offering the widest range of motion, adjustable handrails and seats. Safety features include a Certified Roll-Over Protective Structure (ROPS) and side nets designed for easy in-and-out access. For gear, the unit features a new, rear 300 lb capacity, flat cargo box with Lock & Ride accessory technology and built-in rack extenders to maximize carrying capacity.
Offered in Indy Red, RANGER RZR 570 will be available at Polaris dealerships late fall.
More information about Polaris’ whole line of Off-Road Vehicle offerings can be found online: www.polarisindustries.com
What do you think? Let us know in the forums:
http://forums.atvconnection.com/polaris-ranger-rzr/341032-2012-polaris-ranger-rzr-570-a.html#post3077052
P
