2014 Arctic Cat Wildcat 4 1000s & Prowler 500 Arrive
Back in the beginning of 2013, the Arctic Cat stunned the industry when they announced the Wildcat 4 1000 SxS. For 2014 Arctic Cat has extended the the 4 seat Wildcat 4 SxS lineup with the addition of the 2014 Arctic Cat Wildcat 4 X 1000 and Wildcat 4 1000 Limited Edition. Also for 2014 the Wildcat has a revised hydraulic brake pedal with new lever ratio for more aggressive feel along with new colors and styling.
2014 Arctic Cat Wildcat 4 X 1000 SxS / UTV
For pure-sport ROV enthusiasts who desire to share their adventures with up to three passengers, the 2014 trio of Arctic Cat Wildcat 4-seaters delivers ultimate off-road performance. Joining the Arctic Cat Wildcat 4 and 4 Limited this season is the all-new 2014 Arctic Cat Wildcat 4 X 1000 featuring the powered-up 90-plus-hp H2 engine, 27-in. Maxxis Bighorn tires, and Vibrant Red Metallic and Viper Blue Metallic painted bodywork options.
The 2014 Arctic Cat Wildcat 4 models feature a stretched exoskeleton frame that’s 29 inches longer than the standard Wildcat, to comfortably accommodate the two rear bucket seats with best-in-class passenger ride-in comfort and leg room. All four high-back seats feature 3-point belts, with four tube-frame doors featuring integrated nets.
Unlike competitive brand machines, the driver and passengers are located near the Wildcats’ low center of gravity, leaving them less affected by the movements of the vehicle with greater confidence and control. With an industry-leading 17/18 inches of front/ rear suspension travel and 13 inches of ground clearance, the Wildcat 4 models are built to handle all kinds of terrain with unmatched comfort and control.
The 5-point, multi-link trailing-arm rear suspension design keeps the rear tires planted while the suspension moves through its travel for unmatched traction and control, while the double A-arm front is renowned for its cornering and control. All three models feature FOX Podium gas shocks with compression adjustment. Power comes from the torque-tuned, liquid-cooled 951cc Arctic Cat H2 V-Twin 4-stroke with Electronic Fuel Injection, with a powered-up 90+-hp version in the X model. All three get an automatic transmission with TEAM Rapid Response clutches and feature electronic selectable 2WD/4WD and front differential lock.
Braking performance has been enhanced on all three models for 2014, starting with a new brake pedal that features a new lever ratio for more aggressive feel of the four-wheel hydraulic brakes.
Variable Assist Electronic Power Steering (EPS) delivers light steering input effort when negotiating tough obstacles like washouts, rocks and mud, but with enough feedback so the driver senses the tire contact patch in relation to the terrain. Class-leading LED headlights and taillights shine extra-bright, while a 300 lb. payload rear compartment is large enough to carry a cooler and a gerry can of gas.
Machined, cast-aluminum wheels, automotive-style paint and tilt steering complete the package.
The Wildcat 4 Limited offers two-tone color-matched bucket seats; aluminum front and rear bumpers and bedmounted tie-down hooks.
H2 951cc, EFI, SOHC 4-stroke, 4-valve, V-twin, liquid-cooled engine
CVT automatic transmission with High/Low/Reverse/Park and engine braking
Electronic 2WD/4WD/ Differential Lock
TEAM Rapid Response clutches for quick acceleration
FOX Podium remote-reservoir shocks with 23-position compression adjustment
Double A-arm front suspension with 17 in. of travel 5-point multi-link trailing-arm rear suspension with 18 in. of travel and swaybar
Tilt steering wheel
LED head and tail lights
Four-wheel hydraulic disc brakes with dual-piston front calipers
14-in. machined cast aluminum wheels
300-lb. rear cargo box capacity
Automotive-style painted bodywork
Underseat storage
Glovebox
Bed-mounted tie-down hooks
Dual fan cooling system
27-in. Maxxis Bighorn tires (4 X)
Aluminum front and rear bumpers (Limited and 4 X model)
Color-matched two-tone seats (Limited and 4 X model)
Available in Viper Blue Metallic, Team Arctic Green Metallic and Vibrant Red painted bodywork (4 X)
2014 Arctic Cat Prowler 500 HDX SxS
New for 2014, Arctic Cat introduces the Arctic Cat Prowler 500 HDX, Prowler 500 HDX XT, and Prowler 500 HDX limited Edition SxS / UTV. The all-new 2014 Arctic Cat Prowler 500 HDX and HDX Limited are built to deliver three-occupant adventure and versatility at a premium value.
Both new models are built upon the award-winning HDX design that combines space for three occupants matched by a versatile rear cargo box that’s built to haul a variety of payloads. Large enough to hold items as large as a pallet, the transformable 2-in-1 composite cargo box design that tilts and can haul 600 lbs. payload. Multiple tie-down options ease securing loads. On the Limited model the box features detachable bed sides that quickly transform the HDX into a flatbed.
Each HDX model boasts the sculpted 40/20/40 “bench” seat that delivers comfortable seating for three occupants. It’s part of a spacious cab system that includes a ROPS round-tube canopy.
Power for the new machines comes from the H1 443cc 4-stroke engine with the spot-on calibration of Electronic Fuel Injection. It’s matched by the Duramatic Automatic transmission, which features High/Low/ Reverse/Park and dynamic engine breaking. All three models feature electronic 2WD/4WD selectable by a dash-mounted switch.
For added luxury, the Arctic Cat Prowler HDX XT gets painted bodywork in Emerald Green Metallic or Vibrant Red Metallic, 14-inch aluminum wheels, a 25-lb. capacity under hood storage space, plus left and right side storage compartments.
The Arctic Cat Prowler HDX Limited ups the ante with the addition of 5-position tilt steering, Variable Electronic Power Steering, a locking front differential, 14-inch aluminum wheels, 25-lb. under hood storage and painted bodywork in either Emerald Green Metallic or Vibrant Red Metallic.
H1 443cc 4-stroke engine with EFI, SOHC and liquid-cooling
Duramatic Automatic transmission with High/Low/Reverse/Park and engine braking
Electronic 2WD/4WD
Variable Electronic Power Steering (LTD)
5-position tilt steering (LTD)
40/20/40 sculpted seating for three occupants
41″L x 55″W x 10″D tilting cargo box with 600-lb. cargo capacity and multiple tie-down points
85-in. wheelbase. (10 in. longer than Prowler 700 XTX) for improved ride and hauling capabilities, but retains same 118-in. overall vehicle length
1,500-lb. towing capacity
ROPS certified Wildcat-inspired round tube canopy
10 in. of suspension travel front and rear
10 in. of ground clearance
2-in. front and rear receiver hitches
Electronic gauge with integrated seat belt and park light indicator
26-in. Duro Kaden tires
Front storage compartment with 25-lb. capacity (XT and Limited)
14-in. aluminum wheels (XT and LTD)
Spacious side storage compartments (XT and LTD)
Available in painted Vibrant Red Metallic or Emerald Green Metallic bodywork (XT and LTD)
Available in Green or Red (500 HDX)
