2015 Suzuki King Quad ATV Models Released
Suzuki Motor of America, Inc. has announced the official release of its new and updated 2015 ATVs at a rock-n-roll-infused Dealer Meeting held at the Hard Rock Casino & Resort in Las Vegas including the 2015 Suzuki King Quad 500 AXi, King Quad 750 AXi, King Quad 400 ASi, King Quad 400 FSi.
Redesigned for 2015, the Suzuki King Quad 500 AXi moves to the top of the extremely competitive mid-cc utility ATV class. Starting with the compact 493cc liquid-cooled engine, Suzuki engineers incorporated a new, twin-spark-plug cylinder head for improved combustion efficiency. A multi-hole injector in the Suzuki fuel-injection system delivers a much finer spray, which further increases combustion efficiency.
A new Pulsed-secondary AIR-injection (PAIR) system and new catalytic convertor mean the enhanced engine releases cleaner emissions. Finally, a redesigned inner structure of the exhaust silencer gives the updated KingQuad 500 AXi a more robust riding experience as the engine clears its exhaust more efficiently. All combined, these enhancements help give the engine smoother operation throughout the rev range, producing excellent performance in the mid- to high-rpm range.
The look of the machine is updated for 2015 as well. A rugged front bumper design and new speedometer cover complete the updates to this mid-cc class leader. A new left-side cover allows easier access for checking engine oil level.
Assembled with pride in America at the Suzuki manufacturing facility in Rome, Georgia, the King Quad 500 AXi maintains the features that make it a leading performer in handling, rider comfort, and ease of use. Front and rear fully independent suspension with pre-load adjustment rings mean handling can be dialed in for the terrain or load. The updated engine is mated with an efficient and fully automatic QuadMatic CVT-type transmission.
The King Quad 500AXi Power Steering model features a compact and lightweight electric power steering system, which helps to reduce rider fatigue. The components are mounted high on the vehicle to avoid water and debris. On both the Power Steering and non-power steering model, riders can choose 2WD, 4WD, or differential-lock 4WD to suit the riding conditions.
This KingQuad has a long list of outstanding features, including hydraulic disc brakes up front with sealed, oil-bathed rear brakes, an info-packed gauge display, Suzuki’s signature T-shaped seat, and a fuel tank well positioned below the seat for better weight distribution.
The Suzuki KingQuad 500 AXi is available in Terra Green, and Flame Red for $7,399, and in True Timber XD3 Camouflage for $7,999. The KingQuad 500 AXi Power Steering model comes in Terra Green, and Flame Red for $8,299 (Reduced by $500), and True Timber XD3 camouflage for $8,699. (Reduced by $300)
2015 Suzuki King Quad 750
For 2015, the Suzuki King Quad 750 AXi returns to continue its place as the flagship utility/sport ATV in the King Quad family. At the heart of this King Quad is a 722cc liquid-cooled DOHC 4-valve engine that is finely tuned for low-to-mid range torque along with a powerful high-rpm output. Electronic fuel injection delivers excellent throttle response and fuel efficiency, while delivering power consistently.
The King Quad 750 AXi Power Steering model features a compact and lightweight electric power steering system, which senses steering torque due to changing terrain and applies the correct amount of steering assistance to reduce rider fatigue. The components are mounted high on the vehicle to avoid water and debris. On both the Power Steering and non-power steering model, riders can choose 2WD, 4WD, or differential-lock 4WD to suit the riding conditions.
Assembled with pride in America at the Suzuki manufacturing facility in Rome, Georgia, the King Quad 750 AXi maintains the features that make it a performer in handling, rider comfort, and ease of use. Front and rear fully independent suspension with pre-load adjustment rings allows riders to easily adjust the suspension setup for varied operating conditions. The updated engine is mated with an efficient and fully automatic QuadMatic CVT-type transmission.
This King Quad has a long list of outstanding features, including hydraulic disc brakes up front with sealed, oil-bathed rear brakes, an info-packed gauge display, Suzuki’s signature T-shaped seat, and a fuel tank well positioned below the seat for better weight distribution. The air filter has both paper (for superior filtration) and foam (easily cleaned and re-used) elements for better durability and less maintenance.
The Suzuki King Quad 750 AXi comes Terra Green, and in Flame Red for a retail price of $8,899, and in a True Timber XD3 camouflage version for $9,299. A Limited Edition model in Metallic Matte Royal Gray will be available for 2015 for a retail price of $9,899. The KingQuad 750 AXi Power Steering model comes in Terra Green, and Flame Red for $9,499, and True Timber XD3 camouflage for $9,999.
2015 Suzuki King Quad 400
No matter the job, the 2015 Suzuki KingQuad 400 ASi and KingQuad 400 FSi are ready and willing to tackle it. Both these KingQuad ATVs feature fuel-injected 376cc four-stroke, four-valve engines with new cam profiles and inner structures of the muffler (for more powerful and efficient performance). Suzuki’s class-leading fuel injection contributes to smooth power output, especially, in the mid-to-high range, as well as more consistent cold starts. The fuel-injection system uses 3-D ignition maps for optimum ignition, targeting a responsive yet environmentally efficient performance.
The KingQuad 400 ASi uses Suzuki’s technically advanced QuadMatic transmission-a fully automatic, CVT (Continuously Variable Transmission) with high-low range and reverse. Its advanced engine-braking system minimizes free-wheeling with the throttle off and helps control the vehicle during steep descents.
A five-speed manual transmission with automatic clutch makes the KingQuad 400 FSi a performer for those riders who prefer the personal control of a foot-shift transmission. The KingQuad 400 ASi and KingQuad 400 FSi are assembled with pride in America at the Suzuki manufacturing facility in Rome, Georgia.
The Suzuki KingQuad 400 ASi and 400 FSi models are offered in Terra Green, and Flame Red for a retail price of $6,499. Both are also available in True Timber XD3 camouflage at a price of $6,899.
