Arctic Cat Unveils Three New 4x4s
May 1st, 2011 by admin
While it’s typically considered past the new model release period for many of the major ATV manufacturers, Arctic Cat has built a bit of a reputation for marching to the beat of a different drum. As such the brand has announced word of three new 4×4 ATVs about to be released:
The 2011 Arctic Cat 350 – essentially, an updated Arctic Cat 366 (which began life in 2008) with body work enhancements and additional features
The 2011 Arctic Cat 425i – combining the more compact chassis of the 350 with the fuel-injected 443cc engine found in the larger Arctic Cat 450
The 2011 Arctic Cat 450 XC – a 4×4 crossover machine that’s lighter and more nimble than a utility quad but featuring the four-wheel drive capability
The 350 will feature the following:
• Duramatic Automatic Transmission, with dynamic engine braking and long-life maintenance-free belt
• Only machine in class using hydraulic self cleaning, front and rear disk brakes vs. competitors’ drum brakes.
• CVT is fully sealed with special venting designed to keep dirt, mud and water out.
• Air/Oil-cooling system with high capacity oil cooler
• 3.1 Gears in the front and rear gear cases help to increase low end torque.
• Seat latch allows easy installation and removal for access to the organized tools beneath the seat.
• Industry-leading true independent suspension.
• Maintenance-free bushings
• Kenda tires have been specifically designed for the 350 (24×8-12 front, 24×10-12 rear).
• Single handlebar mounted brake lever operates all wheels with independent rear foot brake.
• Heavy-duty full-length skid plate
• Digital Gauge
The 425 will feature the following:
• Liquid-cooled engine with high capacity radiator
• The only machine in its class to offer low and high range Duramatic Automatic transmission with dynamic engine braking.
• CVT is fully sealed from mud and dirt with special venting designed to keep mud and water out.
• Kenda tires have been specifically designed for the 425 (25×8-12 front, 25×10-12 rear)
• Chassis is close to 100lbs lighter than full-size Arctic Cat ATVs and 61 lbs lighter than the Polaris Sportsman 500
• Single handle bar mounted brake lever operates all wheels with independent rear foot brake
• The only machine in class using hydraulic self cleaning, front and rear disk brakes vs. competitors drum brakes.
• Digital Gauge
• Winch mount-ready front bumper design, for easy installation and finished look
Finally the 450 XC will feature the following:
• 450H1 Engine, 445cc, EFI, SOHC, single-cylinder, liquid-cooled
• Set the spring preload (5 rear positions, 5 front positions) on the shocks to tailor the ride to individual riding styles, terrains and loads.
• Hi/Lo-Range allows responsive acceleration and engine braking. Transmission also features start-in-gear to get you going faster.
• Gauge displays critical operation information indicators including: clock/hour meter, fuel level,mode button, set/reset button, odometer/trip, gear position, speedometer/tachometer, needle display, drive select, high beam, battery condition, temperature and oil pressure.
• 2-in. receiver allows the consumer to remove the hitch from their 2-in. automotive receiver and install it into the ATV’s receiver hitch.
• Other premium features include zero-maintenance suspension bushings, sealed drive shafts, a large 4.3-gallon fuel tank and durable, full-length plastic skid plate.
For more information on this new trio or Arctic Cat’s entire line visit the following URL:
Does Arctic Cat’s new trio interest you? Let us know!
