Ask the Editors: Help! I Loosened the Wrong Drain Plug
Cam_Tensioner
Dear ATVC: I went to change the oil in my new Coolster 110cc atv and instead of the drain plug I removed the smaller plug on the opposite side. A spring came out and then a small metal shaft. The shaft has a black plastic cap on one end and I’m not sure which end goes in first . Thanks for any help! Beastmode15@outlook.com
The good news? You are certainly not the first person to make this mistake. The plug you mistakenly removed was actually the machine’s cam tensioner.
Fortunately getting it back in action shouldn’t be much of an issue. Refer to the following schematic to assemble it in the proper order:
Order_2
