Can-Am DS 450 Modification Arrives
April 11th, 2010 by admin
P
Massive Cranks Yield Impressive Numbers
By: Jason Giacchino
Falicon_Crank
Can-Am DS 450 fans have cause for celebration as a new performance modification is about to be unleashed for the power hungry. In developing the largest stroker crank for the Can-AM DS 450 ATV, Falicon Crankshafts Components partnered with Eric Oldham at Oldham Machine Works (OMW). Together they pushed the envelope by stroking the OEM crankshaft + 8mm (68.8mm overall stroke), balanced to a 14:1 high compression stroker piston.
This process turns the 450 into a whopping 508.4cc without altering the stock bore set-up! By boring the stock cylinder 99mm, the displacement numbers get even crazier at 529.6cc.
Can_Am_ds450
This set-up is exclusively offered through OMW and the kit package includes: Beehive spring kit, billet intake race cam, head porting, Falicon stroker crank with Knife Rod (customer must supply crank core), 14:1 stroker piston, including a power commander map for this combo. Currently a + 10mm (70.8mm overall stroke) crank is in development that would produce 523.2cc with the stock bore configuration, and 545cc with the 99mm bore option.
OMW Racing
omwracing@yahoo.com
1421 Oldham Rd.
Barlow, KY 42024
(270) 334-3331
Falicon Crankshafts Components, Inc.
sales@faliconcranks.com
1115 Old Coachman Road
Clearwater, FL 33765
(727) 797- 2468
Does the Can-AM DS 450 mod impress you or is it a joke? Discuss it here!
P
