Dura Blue Posi-lock Axle Nut
DURA BLUE POSI-LOCK AXLE NUT FOR HONDA ATC350X, TRX250X, 300EX, 250R |
The Dura-Blue Posi-Lock axle nut is a two- piece assembly with the center threaded piece having flats for a wrench. This way you can force it free. To prevent the nut from ever coming loose before you want it to, the Allen screw is tightened, squeezing the threads sideways. To install the Dura-Blue Posi-Lock axle nut, coat the two pieces of the nut and the axle with Never-Seize to prevent corrosion. Make sure the O-ring against the disc brake carrier is in good condition. Slide on the nut assembly. Place the provided spring clip in its groove. Hold the threaded collar with a wrench and spin the outer hex nut to expand the assembly over the spring clip. Tighten until there is no play in the axle, but don’t overtighten! You will warp the hub’s ball bearings sideways. Finally use an Allen wrench to tighten the set screw. Check the bearings frequently to keep tabs on the inevitable wear and you are ready to ride!
