Kawasakis All New Race Ready KFX 450R
January 1st, 1970 by admin
Building on the success of Kawasaki’s highly acclaimed KX™450F motocross engine, the all-new, race-ready KFX®450R is the first sport class ATV to offer a light-weight, all-aluminum frame for optimal handling and superior rigidity needed on the track. Another first in this class is a competition-oriented reverse gear, perfect for getting out of those first-turn traffic jams or dead-ends on tight trails. The Keihin fuel-injection system maintains crisp engine response, regardless of altitude or outside temperatures. The racing-style chassis features a single box tube lower frame tube which allows maximum lower A-arm length. This highly advanced ATV racer comes with all of the performance and technology necessary to put you at the head of the pack, without the hassle of modifications. It’s also easy to work on, so riders can spend less time wrenching and more time riding.
KAWASAKI’S ALL-NEW RACE-READY KFX®450R ATV FULLY EQUIPPED WITH RACE-WINNING PERFORMANCE
September 26th, 2006
By: Press Release
By: Press Release
Building on the success of Kawasaki’s highly acclaimed KX™450F motocross engine, the all-new, race-ready KFX®450R is the first sport class ATV to offer a light-weight, all-aluminum frame for optimal handling and superior rigidity needed on the track. Another first in this class is a competition-oriented reverse gear, perfect for getting out of those first-turn traffic jams or dead-ends on tight trails. The Keihin fuel-injection system maintains crisp engine response, regardless of altitude or outside temperatures. The racing-style chassis features a single box tube lower frame tube which allows maximum lower A-arm length. This highly advanced ATV racer comes with all of the performance and technology necessary to put you at the head of the pack, without the hassle of modifications. It’s also easy to work on, so riders can spend less time wrenching and more time riding.Race-inspired Engineering:
- Race-winning performance right from the crate
- Rigid, light-weight all-aluminum frame is a class exclusive
- Racing-style chassis with single box tube lower frame
- Closer lower A-arm pivot points help reduce bump steer and lengthen suspension travel
- Competition-oriented reverse gear is a class exclusive
- Keihin fuel-injection with 42mm throttle body
- Plenty of low-mid range torque for higher cornering speeds and unbeatable handling
- Front and rear fenders feature two-piece construction for easy replacement
- Easily detachable front headlights
- Petal rear brake rotor for more efficient braking performance
- Renthal FAT-BAR is held by a clamp that can accommodate other MX handlebar designs
