Motor Master CV Rebuild Kit
In the past, repairing a worn or damaged OEM CV joint for an ATV or UTV often required replacement of the complete CV axle, as many manufacturers don’t offer components to rebuild the OEM CV joint itself. Replacement options were limited to an expensive OEM CV joint or CV axle, or a less expensive and lower quality aftermarket CV axle.
For some vehicle models the only option was a new OEM CV axle, as no aftermarket equivalents exist. Now there is a new and better alternative; Motor Master ATV Products CV Rebuild Kits. The kits contain a new inner race, cage, bearings, CV boot, snap rings, grease and detailed instructions to properly rebuild ATV and UTV OEM CV joints to original specification. Thereby allowing the original CV axle to be retained, and at a fraction of the cost of a new OEM unit.
Top quality components are used in CV Rebuild Kits including precision engineered inner races and cages, premium polyurea based grease, and Motor Master Duraboot high-strength CV boots that provide greater strength and durability than OEM CV boots. Motor Master provides inboard and outboard CV joint rebuild kits for a wide range of ATV’s, UTV’s and Minitrucks. Made in the USA. For more information, contact Motor Master ATV Products at (815) 312-5728, or click here.
