New AntiVibe Bar Mount for Can-Am DS 450
January 3rd, 2008 by admin
P
New Anti-Vibe Bar Mount for Can-Am DS 450 available from Epic Racing Products
Las Vegas, NV, February 29, 2008 — The new Isovibe for the Can-Am DS 450 is now available from Epic Racing Products. The anti-vibe mount absorbs handlebar shock and vibration and allows the use of 1 1/8″ handlebars.
The Isovibe is better than standard anti-vibe steering stems that only absorb vibration. This new Isovibe absorbs vibration and shock in forward, rearward, vertical and side-to-side directions. The Isovibe is also less expensive than adding an anti-vibe steering stem.
The main function of the Isovibe is to absorb vibration and shock that would normally be transferred to a rider’s wrists, shoulders and arms when landing jumps or hitting hard bumps. If you’ve ever landed a jump unevenly you’ve experienced side-to-side impact to your wrists, that can sometimes literally rip the bars out of your hands. The Isovibe SX will absorb this impact and keep you in control.
Adjustable handlebar deflection – simply add or remove shims between the bushings to increase or decrease the front-to-back deflection. Add or remove shims on the top and bottom sides of the bushings to increase or decrease the side-to-side deflection.
Two height options are designed into the Isovibe SX, to raise the bar mounting point by 1″ or 1 1/2″ over stock, depending on how it is mounted. Two bar offset options also. Same as stock or 1/2″ forward bar offset.
The Isovibe SX model is for 1 1/8″ bars.
Anti-vibe mount can be purchased online at http://shop.EpicRacingProducts.com . MSRP is 9.95
About Epic Racing Products: Epic Racing Products manufactures only the highest quality racing components. We race what we sell. Epic Racing Products and suspension components can be found on the ATVs of top riders from coast to coast, including Factory Can-Am riders Jeremy lawson, Greg Gee, and Sage Baker.
P
