NEW from Superwinch drum-centric ATV2500 and ATV3000
January 1st, 1970 by admin
P
NEW from Superwinch,
Drum-centric ATV2500 and ATV3000
Rock solid line of ATV/UTV Powersport products to get you unstuck
Febuary 14th, 2007
By: Press Release
undefinedPutnam, CT – February, 2007 — Superwinch, Inc., the first company to manufacture winches for ATV’s, is proud to introduce the ATV2500 and ATV3000, centered winch drum, 4-bolt pattern winches serious enough to carry the Superwinch name and a limited lifetime warranty.  The new winches feature the same fail-safe electrical components (like a premium, sealed solenoid) that have kept Superwinch products performing for years.  These CE certified winches operate at a reduced amp draw to minimize electrical system drain on most ATV models. The hefty, sealed 1.5 hp motor provides reliable performance for the most dedicated off-road Powersports enthusiast and includes easy to view color-coded wiring for fast simple installation.
Superwinch continues to produce hardworking long lasting products with full metal gear sets, sealed drive trains and top grade hardened metals that out last the competition. A high-speed motor combined with 3-stage planetary gears deliver a fast, yet safe pull to get you unstuck in a hurry. Dynamic and mechanical braking are combined in these new models to produce sure stops and Samson-like holding power. The cam-action freewheel operation is easy to engage and disengage and the sealed and potted handlebar switch can be placed to accommodate your personal comfort and is easy to use even while wearing heavy gloves.
The Freedom Switch wireless system is also available for these winches.  With versatile mounting possibilities, the Freedom Switch can be easily installed on any ATV and operated reliably from up to 150 feet away.  Like all other Superwinch DC products, each component is sealed for all weather, long-lasting performance.
About the manufacturer
For over 37 years, Superwinch has produced AC and DC electric and hydraulic winches, mounting kits, 4wd locking hubs and accessories for racing, recovery, and off-road and industrial uses. For more information, contact Superwinch at 860-928-7787 or visit the company website at www.superwinch.com.
P
