Odes Introduces 500cc Touch-Screen Equipped UTV
comrade_2
The Comrade is the first 500cc side-by-side offered by ODES. The company added the $7,799 unit to their 2017 model line based on consumer and dealer demand.
“It’s just an inexpensive, price point, 50-inch model for the trail width and a good little farm vehicle, so it kind of hit three things at once. A lot of dealers wanted that instead of just the high-end stuff,” said ODES CEO Mike Smith.
Despite a low MSRP, the Comrade will come loaded with accessories. The Comrade comes stock with a 2,500-pound winch, hard doors, an ABS molded roof, a tilt dump bed, a plexiglass windshield, an oversized cargo box and more. EPS is optional.
Perhaps the most anticipated feature, however, is the all new 7-inch Zeus Touch touchscreen.
zeuse
Using the Zeus Touch, riders can harness GPS technology to map routes and track their own waypoints and use Bluetooth technology to see incoming call and text notifications. They can also view all gauges and indicator lights through this interface.
The Zeus Touch LCD will now be standard equipment on the Assailant 800cc ATV and the Dominator X2, Raider and Dominator X4 1000cc UTVs. It’s optional on the Dominator X2, Dominator X4 and Raider 800cc side-by-sides.
The Comrade will be offered in flat sage green, silver metallic, or shiny red, and it comes standard with a two-year warranty.
For more information, click here.
comrademain
ENGINE
Engine Type 500cc – Single Cylinder 4 Stroke
Horsepower 25 Horsepower
Engine Oil Royal Purple 10w/40 Max Cycle Synthetic Oil
Max Torque 42.04ft.lbs / 4250 RPM
Compression Ratio 9:4:1
Valve Configuration SOHC
TRANSMISSION & DRIVE
Drive Type Fully Automatic
Gears L-H-N-R-P
Clutch CVTech Clutch System™ and AMT
Drive Shaft Drive Front/Rear
4×4 Capable 2×4, 4×4, Differential Locking Switch
SUSPENSION
Front Suspension Independent Double Arm
Rear Suspension Independent Double Arm
BRAKES, TIRES & WHEELS
Front/Rear Brakes 4 Wheel Disc Brakes
Front Tire Mudder 25×8-14
Rear Tire Mudder 29×10-14
Front Wheel 14″ Steel Wheels
Rear Wheel 14″ Steel Wheels
MEASUREMENTS & DIMENSIONS
UTV Dimensions 115″(L) x 55″(W) x 72″ (H)
Cargo Bed Dimensions 37.4″(L) x 42.9″ (W) x 11.81″ (H)
Unit Width 55 INCHES
Ground Clearance 14.4 Inches
Weight 1146LBS
Towing Capacity 2200LBS (330 Tongue)
SPECIAL FEATURES & INCLUDED ACCESSORIES
FRONT WINCH STANDARD 3500LBS
PATENT REAR WINCH OPTIONAL
ROOF / FULL WINDSHIELD INCLUDED
2″ TOW BALL WITH HITCH INCLUDED
HALF DOORS INCLUDED
LED LIGHTS INCLUDED
REAR BUMPER INCLUDED
SNAP PUSH PINS INCLUDED
STITCHED SEATS INCLUDED
DAYTIME RUNNING LIGHTS INCLUDED
