Baja QJ 250 ATV Gearbox
leonaard graham,
Is it the gear inside the gear reduction box which I guess is closer to the cvt belt or the gear in the actual fwd/rev box bolted to the output shaft of the reduction box? If you can send a pic of the gear I might have it, I did away with the fwd/rev box and just have fwd now with a custom made sprocket on the splines of the gear reduction output shaft. So I have the gears from the fwd/rev box just two of them (not sure exactly which ones) are missing teeth. If I have the gear I would gladly send it to you for postage. Also I have a question for you, could you get me a pic of the wires going into the cdi box, I desperately need this to get mine running again. The plug that goes into the box fell apart and I dont know what color wires go where on the cdi box. There is five wires and one unused plug. If you cant get a pic of it just telling me in what order they go on would be great.
Let me know,
Cole
Let me know,
Cole
#17
I will get pictures of what I got this weekend, I just have to dig them out of storage, is it the gear attached to a shaft, I know that one is good, I am not sure till I look at mine again but I think the wires you described are for the rectifier i believe (not 100% sure its been a while since I looked at it) that the wires to the cdi are red, black, green/white strip, below,while strip and so on. The cdi is all black on mine the rectifier is aluminum but mounted close to the rectifier.
Thanks,
Cole
Thanks,
Cole
#18
Does anybody know the correct belt for this atv? Where to buy it? Please give me one online shop. Thanks!
Amoxicillin Dosage
Amoxicillin side effects
Amoxicillin Dosage
