Roketa 250cc Wont idle/run correctly
Old 05-22-2011, 07:42 PM
ChristopherSeiffert's Avatar
Default Roketa 250cc Wont idle/run correctly
I have a 06 Roketa ATV04 RTK250w Atv, with the water cooled honda clone motor in it. It's got the PZ30 carb.
For some reason it won't idle correctly. I've changed the carb twice, changed spark plug, adjusted the valve lash. Drained the fuel, cleaned the fuel tank, replaced the fuel lines, cleaned carbs out, everything. It idles like ***.
The Symptoms:
Starts sometimes with choke, sometimes without choke. Idles high, then goes low, sometimes so low it dies, then idles higher again. Adjusting the air mix screw does not result in much difference unless I turn it a full turn!
I tried to jiggle wires to see if there was a bad connection, checked to see if the ignition timer was loose but I can't seem to find anything wrong with any of the parts. What do I do?????
Old 05-25-2011, 02:36 PM
Overdrive's Avatar
Air leak in the carb boot.
scrounga
Honda Side by Sides
03-07-2016 04:17 AM
Impalaman
1) Engine problems..
12
11-08-2015 07:17 AM
1ArmBandit
55
10-14-2015 09:03 PM
2many2ride
09-27-2015 04:35 AM
Nosniborpapa
09-19-2015 07:07 PM
Quick Reply: Roketa 250cc Wont idle/run correctly
