Coolster atv 3050B 110CC carburetor
I have been trying to get my son's atv to run as it has been parked at his uncle's farm for some time. I have replaced several parts and went to fill it with fuel. On the right side of the carburetor there is a tube towards the top. Fuel is coming out of this tube. Am I missing something? Is there supposed to be a hose of some sort connected to this and if so where does it connect to? Any help is greatly appreciated.
you should post a pic if you can, then I may be able to help
it has been a while since I have messed with the carb, but I only remember the fuel in hose on the side, and the drain hose on the bottom
there is also a crank breather hose that goes into the filter
does your carb look like this?
http://www.flickr.com/photos/78121832@N00/6950092634/http://www.flickr.com/photos/78121832@N00/6950092634/ by http://www.flickr.com/people/78121832@N00/, on Flickr
that is the right side and there arent any hoses.. the fuel feed is on the other side and faces up as seen here
http://www.flickr.com/photos/78121832@N00/7096162731/http://www.flickr.com/photos/78121832@N00/7096162731/ by http://www.flickr.com/people/78121832@N00/, on Flickr
quad 3 by dkluck1, on Flickr
quad 2 by dkluck1, on Flickr
Jersey General
1) Engine problems..
09-13-2015 01:05 PM
