Leaking from crankcase.. From left side of motor125 Chinese utility atv
Old 02-03-2019, 12:10 AM
Booberry33's Avatar
Default Leaking from crankcase.. From left side of motor125 Chinese utility atv
My grandson drove the atv without any gear oil in the gear box,the wheels locked,and it would not click n gear,I then filled the gear box with gear oil, it unlocked ,but it shifts a tiny bit hard here and there ,but now i have a gear oil leak on the left side of the motor, right at the bottom corner screw of the crankcase cover, what is the problem and is it a bit fix
Old 02-03-2019, 03:23 AM
This is a how long is a piece of string question, as we don't know the make. Most quads have the engine and gear oil shared, so it isn't a common make. At a guess I would think the gasket has gone so, case off, fit new gasket, or it may just be sealed with "goo," but expect a shower of gears and washers to drop out when you take the case off.
Booberry33
03-25-2019 03:35 AM
rider269
06-10-2011 08:51 PM
Casey25
Utility ATVs
17
09-11-2007 03:01 PM
bertoprox
08-07-2004 11:17 AM
Quick Reply: Leaking from crankcase.. From left side of motor125 Chinese utility atv
