Hensim 150cc drive will not engage
Old 10-23-2012, 06:57 PM
Jess1610's Avatar
Default Hensim 150cc drive will not engage
Took the quad out today was working great after awhile it started coming out of drive.. Sounds like something was just spinning inside the trans... My suggestions??????
Old 10-23-2012, 07:55 PM
archinut's Avatar
What type motor do you have. If it is a gy6 clone motor (same motor found in 150ccthe scooters) it sound like you broke the cvt drive belt, which is an easy and inexpensive fix. I usually keep a couple on hand. They range from $10-$50. I just use the less expensive kinds found on ebay.
Old 10-23-2012, 08:02 PM
Jess1610's Avatar
That's what I thought so I removed the side cover and the belt was good.. So I was checking it out and I have to rev the eng high so the auto clutch will engage then it jumps forward and comes out of gear...
Old 10-23-2012, 08:18 PM
archinut's Avatar
When it jumps out if gear, is the clutch still engaged (the clutch bell still spinning)? If it is still engaged then your issue is in the reduction/reverse gear box. If the bell does not stay engaged your issue is the clutch. Either the clutch pads are worn or the clutch springs.
Old 10-23-2012, 11:31 PM
LynnEdwards's Avatar
Electrical Expert
I agree with all of Archinut's observations.
Here is a simlar (recent) post with perhaps some more info to ponder:
http://forums.atvconnection.com/chin...ing-right.html
Be sure to read from top to bottom. The middle section gets off subject a bit, but it is back on track towards the end.
Old 10-23-2012, 11:33 PM
Jess1610's Avatar
When I shift it to drive it doesn't engage.. As I rev it it starts to engage then disengages....
Old 10-23-2012, 11:37 PM
Electrical Expert
No gear grinding?
If there is no gear grinding then I'm leaning towards archinut's advice...
MaasaiMomma
03-25-2021 11:24 AM
Polaris5
08-29-2015 09:11 PM
frostphase
08-19-2015 07:11 PM
KimSJoh
14
07-18-2015 07:20 PM
ghost civic
07-15-2015 10:48 PM
Quick Reply: Hensim 150cc drive will not engage
