What causes ATV to no longer generate a spark???
My ATV was running perfectly fine last weekend. All of a sudden it stopped working. I am not sure what happened.
I need to know everything to check to make sure there are no shorted out grounds, no burnt out wires.
I need to know everything that is involved in ignition process.
Thanks.
Thanks.
What kind of ATV is it and did you remove the spark plug from the head to see if it's sparking? If it's not the spark plug itself, then its most likely the spark plug coil. You can perform a meter test on the coil just to be on the safe side and that would be a pretty cheap fix. If its not either the plug or the coil, then attention should be focused on the CDI itself.
You need a multimeter to check continuity on the cables and to see if voltage comes through.
First check spark plug wire, if theres power the plug is defective.
Then check wire from cdi to coil, if theres power then coil is defective.
Then check power from stator to cdi. If there is power then cdi is defective, if no power then stator is defective.
This only applies if youve checked vital wires for continuity
What setting on the multimeter should I have it set at?
And how should I test it?
I mean that if there is voltage from the stator to the cdi, but not from the cdi to the coil this could be both a defective cdi and wiring problems such as the grounding from the cdi being bad
How can I test that? Like can you name everything step by step for me to test this? I am new to testing all this and required very detailed instructions. Thanks,
However, if you're new to this and its a fairly expensive atv id recommend getting an expert to look at it.
I can do it, I just need to know exactly what needs to be done. Then I'll be fine. I have done a lot of work to the machine and I am refusing to send it to someone when with then right information I can do myself. I just need to know what to do.
1. The stator creates voltage (plus on multimeter on wires from engine to cdi and ground to battery)
2. Voltage reaches the coil. (Checkef by testing wire from cdi to coil)
JenniferM
03-17-2024 08:21 PM
TaoTao110D
01-21-2016 01:23 AM
60studehawk
01-18-2016 11:07 AM
newtonty
01-16-2016 03:09 PM
jmelton
Ask the Editor
01-07-2016 06:58 PM
