2) Chassis problems.. If your quad runs but you have other problems.. post in here.
3 bolt starter E22 motor
Old 01-29-2015, 09:27 AM
BruceDeuce's Avatar
Default 3 bolt starter E22 motor
Seems after I took the starter off the bolts were misplaced. Loncin E22 110 Would appreciate if someone could tell what size they are so I can go buy new. Thanks
Old 01-30-2015, 04:09 AM
You could be lucky, I'm changing the starter on a Lienmei Quad. No idea of what the engine is but it has a 3 bolt starter on top of the engine with a 12 tooth sprocket driving a chain down to the back of the flywheel. Anyway the bolts are M6 x 50mm long.
Old 01-30-2015, 08:21 AM
BruceDeuce's Avatar
Thank you, that did steer me in the right direction. I had 6-1.00x40 and they worked . Thank you Sir!!!
ghost civic
01-15-2020 07:43 AM
Ripinandtearin
1) Engine problems..
12-11-2017 08:06 PM
ghost civic
07-19-2015 10:13 AM
Desimation2k8
07-17-2015 12:37 AM
ghost civic
07-15-2015 10:48 PM
Quick Reply: 3 bolt starter E22 motor
