Does it usually take a long time to bleed brake?
Now I need to figure out a way to bring the handle toward the handlebar a good amount, my son has tiny hands, it's impossible for him to reach and pull. Someone said they had luck placing a broom handle inbetween and bending the handle. Not sure how a cheap chinese casting would hold up to that. I thought about grinding at the master plunger "tab", but there isn't really enough meat there once it's ground out. I may have to just cut a new handle with a different profile.
you could pull it off, stick it in a vice, heat it up and form it more into a deeper "j", then see if there is room to slide it further into the middle of the bar so that the newly bent section is closer to the grips...you will likely loose stopping power...
Need to figure out the same for my kid's LT80R...I was actually looking at sled masters/levers...they tend to be short and have 1 finger stopping power...with that power being very early in the stroke...
#15
How does the sled master's achieve the extra stopping power? Do they have the master cylinder piston positioned farther away from the pivot point? I don't see a way of doing that on mine, so extending the handle is my only option to make it easier to pull.
#18
