Small Questions Thread
Well.. I've got a small question and I figured a thread like this might be a good idea to keep the small things bunched up.
So Ask away.
But I'll go first.
Would anyone happen to know where the engine RPM wire for a digital speedometer is connected and how it works?
I'm going to be making my own speedometer/odometer/tachometer since the stock one burned out a while ago and I'm not exactly up to paying 80€ for a stock new one.
I've got most of it figured out including a way to get the RPM reading, but since the stock loom is still in place I figured it'd be easier to just use up what I can from that.
So Ask away.
But I'll go first.
I'd do the coil around the spark plug thing if I wanted to DIY it completely, but since stock loom is in place I figured I could just use that.
I can figure it out on my own fairly easily, I'll just hook up my oscilloscope and try out every pin until I get a signal that varies as I rev the engine.
Then I'll go with that.
sorry im new and dont know how to post lol but do have a ?
i have a 2001 honda rubicon foreman 500 and i took my water pump off to see if its ok it looks bran new in side and the fins turn but not fast its a little tight to to hard but it not free spin is that normal or is my pump bad and hod do i get the fins off to grease it i just got this quad and its my first
