valve stems front tires 16x8-7
Old 08-03-2016, 10:07 PM
bubba143826's Avatar
Default valve stems front tires 16x8-7
taotao valve stems will come all the way out!is this normal? how can i fix this or do i need new tires/rims? thx n advance
Old 08-04-2016, 09:54 AM
Zrock's Avatar
Super Quad Patrol
not sure what your saying? From the factory they loosen the insert in the valve stem to let the air out. You have to tighten it back up
Old 08-04-2016, 10:10 AM
Default how do i tighten them?
dont think they need to be tightened. when i put air in the center will pull out, and slowly leaking air
Old 08-04-2016, 10:31 AM
Zrock's Avatar
Super Quad Patrol
Ya u need to replace that. Ant tire shop can do it or get the new stem and do it yourself. I have pushed the old ones into the tire and then soaped up the new one and pushed it in from the front with the help of a screwdriver
Old 08-04-2016, 11:29 AM
Talking valve stems
so i can purchase new ones and install them into the rim? if i understood that correctly. buth pieces shown in pic get replaced and they are not supposed to come apart. wow thx so much i was going to buy 2 new wheels and rims this will be alot cheaper i know
Old 08-05-2016, 09:43 AM
Zrock's Avatar
Super Quad Patrol
yep change em out.. you can find new stems anyware.
Old 08-05-2016, 12:21 PM
LT80's Avatar
LT80 Expert
It looks to me like you have a 2 piece stem. I've not seen one.
I think Zrock is explaining to remove all that you have on there and put a regular rubber stem in like millions of vehicles have. There are 2 sizes. Measure the hole on the rim so you know whether to get the lil or big stem.
Old 08-05-2016, 09:30 PM
Default valve stems
thx for your help i found some 90 degree one piece valve stems on ebay im gonna get. I'll be sure to measure the holes first.
Old 08-07-2016, 11:02 AM
Zrock's Avatar
Super Quad Patrol
Its not a 2 pc stem.. All rubber valve stems are the same. Just the glue on that one finally let go and spit out his insert.
grumpyjarhead
06-28-2021 12:33 AM
bradleyheathhays
07-24-2016 03:55 PM
Boxertim
07-07-2016 08:06 AM
swimdad
06-18-2016 08:12 PM
Quick Reply: valve stems front tires 16x8-7
