neutral idle vs in gear
We have a used 110 that has and idle issue when in neutral. The idle is extremely high until it is shifted into forward gear. Once in gear, the idle is normal. I have cleaned the carb, checked the throttle cable, and adjusted the idle when it is in gear. Any ideas and help would be greatly appreciated.
Thank You,
Tolwich
Thank You,
Tolwich
