View Full Version : Chinese Quads - Ask an Expert!
Pages : [1] 2 3 4 5
  1. Looking for manual and data of this kids quad...
  2. Sunl sla-109
  3. wiring problems
  4. please can someone give a little heads up on this one
  5. Some Help needed
  6. 2007 RedCat 200cc ATV
  7. 2nd post No Power Chinese 90cc
  8. sunl 110cc atv electricity help
  9. 2006 hibird
  10. Help me identify what this quad is
  11. Complete Rewire Loncin110 Please Help
  12. BMX 300cc 4X4, HELP!
  13. 110 loses spark after 2 minutes
  14. Fa-c70
  15. 125cc atv need help with fuel lines and vacuum lines
  16. Chinese 110cc quad complete rewiring help.
  17. Chinese APC 90cc dies at full throttle
  18. unknown name atv 110 cc turns off when accelerated
  19. Zhejiang Xinshun 250cc quad
  20. Xs-d055
  21. Piston / Cylinder Decision
  22. mad cat 110 wont start help !!!
  23. Baja 90 no spark first post
  24. regulator/ battery
  25. Chinese Quad Starter Problem
  26. need a little guidance
  27. 2005wildfire 250cc atv
  28. roketa 800 parts swap
  29. baja150cc gy6 no spark
  30. I Hate This China Crap Quad
  31. oops wrong bolt !
  32. Help Identifying name of Chinese 110 atv
  33. I need help
  34. frustrated mechanic fixed
  35. warranty
  36. Tao Tao 125-G
  37. Seized
  38. where do I go from here?
  39. Spark only sometimes
  40. Help IDing a chinese quad
  41. 3 chewed up starters arrrrghh!! please help
  42. bashan speedo all over the place
  43. frustrated mechanic take 2
  44. Baja ba250
  45. Frustrated mechanic
  46. 2008 linhai rustler 250 4x4 wnt start somdays
  47. starter won't crank fast enough
  48. Blown fuse...or worse?
  49. 200 cc Chinese ATV
  50. kuzuma spindles
  51. Kazuma falcon150 aftermarket parts?
  52. e-ton viper 90 got gas and spark scts like it wants to run but won't
  53. 90cc chinese quad wont start. cranks but wont fire
  54. 135cc Tao Tao quad how can I increase the speed
  55. 2006 Baja 90 drive train noises
  56. 2008 hi-bird QH-250 stw
  57. GY6 250cc no spark
  58. TAO TAO ATA 200 2009 model Clutch Help
  59. loncin 72cc wirring diagram
  60. GY6 150cc top end rebuild problem
  61. hammerhead twister 150 ignition problems??
  62. ATA 125D - Squeling noise
  63. Please, please help me.
  64. Baja wd250-j gear box parts
  65. 250 Twin cyl no spark
  66. Agravated
  67. Help Identifying Stator Plate
  68. New PZ19 carb runninf almost full throttle
  69. Tomoto Parts
  70. spark plug?
  71. no spark 110 cc chinese atv
  72. Loncin 110 - new battery not charging - Help Plse Lynn??
  73. Mt toa toa 125 won't Start
  74. 110cc dies after getting hot
  75. 125cc motor runs until start fluid burns off
  76. 110cc - new wiring harness and switch
  77. 110 coolster
  78. need help finding model and brand
  79. green wire on negative battery?? started smoking
  80. jianshe 400 mountain lion transmission
  81. Baja 250 atv
  82. Kazuma Meercat 50 - stalls in gear
  83. 110 taotao burnt stator
  84. Tao 250D winch mounting plate?
  85. Qiye Coolster won't crank
  86. Tao Atv won't move
  87. 2005 110 Zackal, 4 pin CDI Wont Spark
  88. need help identifying engine size possibly make and model
  89. 2007 350cc Has No Spark
  90. Where is CDI box located?
  91. lifan 50cc quad acting strange please help!!!
  92. TaoTao 125D Won't start/stay running
  93. AC vs DC power
  94. 2007 baja wilderness 250 tranny issue
  95. Dinli Dino 50cc carb questions
  96. 110 cc Chinese ATV cranking but not popping
  97. Rocketa 250cc not starting
  98. Hensim 150cc popping, backfire with new carb
  99. 110cc not cranking
  100. buyang fa-70 idles but dies with throttle
  101. Predator 260 overheating issues
  102. coolster 110cc sat a long time
  103. ATA-125D electric works intermittently
  104. Stator swap?
  105. runs wide open
  106. Coolster 125cc alternator heating up
  107. Jackel 50 atv please help
  108. 125 Tao Tao wont start
  109. 110 quad losing power
  110. Valve clearance settings
  111. peace 110 quad stopped running
  112. Chinese quad
  113. 90cc kazuma
  114. Kazuma 110 Falcon Carb question
  115. Clutch will not disengage 250 water cooled
  116. Loncin dirt bike no spark
  117. QLink Frontrunner 700 brake bleeding help requested!
  118. flywheel removal
  119. engine type?
  120. tao tao 250C
  121. Do you always have spark.
  122. compatible stator!
  123. Wildfire 110 (q2) stator smoking when attempting to start??
  124. tat tao ata 250-e
  125. 110 sunl timing question
  126. NO spark lots of frustration
  127. 2013 Mountopz 125cc nothing but a headache please help
  128. 2006 HiBird HS 250
  129. Buyang 300- Idles fine/Dies with throttle
  130. LINHAI Rustler 300
  131. Help please Lynn
  132. wilderness 250 baja
  133. Kazuma 110 that won't quit running, Help Lynn !!!
  134. Basic wiring
  135. A few questions for you Carb Experts
  136. 200cc komoto 4wheeler
  137. Electric choke conversion
  138. kazuma water pump replacement
  139. Sunl 110cc Quad not charging?
  140. Loncin 250cc gear problems
  141. Dinli Carb Question
  142. Oil leaking from Magneto cover on 110 Kazuma
  143. electrical issue
  144. What is missing?
  145. need to finds parts for my Jetmoto 250 hunter
  146. Chinese atv overflow from carb
  147. Linhai 300cc (275cc) no spark
  148. SunL110 Wont Start, please help
  149. Unknown Quad - VPMOTOR
  150. aldy 300 blowing up cdi boxes
  151. 110cc hanma wiring diagram
  152. Help With Identifying 4Wheeler
  153. Eton 50 m no start
  154. Hisun HS400 4x4
  155. blowing fuses
  156. china atv carburetor level not working
  157. 2008 Tomoto 500cc atv looking for engine clone
  158. School Me on a Denli 90cc Diamondback
  159. Help with unilli eagle 160 please
  160. 125cc siezed up!
  161. Looking for PARTS?
  162. Help with A kAZUMA 250
  163. Need Help Identifying please
  164. Identifying a Chinese Quad?
  165. Please help!
  166. Bashan Blue and White Smoke When hot
  167. Identifying a Chinese quad.
  168. Tunning and Parts
  169. i need help with my yamoto 110cc dose not start
  170. kazuma 50 cc quad cuts out plz help
  171. fuse problem fixed
  172. battery short in the fuse?
  173. blowing fuses
  174. eton 50 top speed
  175. Who's found the cheapest Hammerhead parts?
  176. Komoto 125
  177. fuse gets hot and wont start?
  178. kazuma 200 cc wont start
  179. redcat 150cc atv carburetor
  180. Modifying Clutch on 110 and 125 auto
  181. polaris magnum with linghai engine.
  182. My gy6 150cc jumps time
  183. 2006 ricardo 100 atv
  184. Need help with kill switch
  185. New guy here..Quad wont spark..help Lynn
  186. Chinese ATV Runs Good But Cuts Off
  187. kasea mighty mite 50cc 2stroke who has 1
  188. No reverse on Pease Sports 110 ATV
  189. i need some help please
  190. Hisun 700 ATV
  191. chinese 110cc no power
  192. prob with transmission
  193. coolster mountopz atv 125cc
  194. 72CC Buyang BMX Mini Quad Bog ?
  195. atv-21 arc
  196. Pz20 carb idle screw
  197. Tao Tao 125D keeps blowing fuses!!
  198. removing gy6 motor from dune buggy?
  199. China 110 Ignition switch wiring
  200. YS110 Wiring Diagram
  201. Carb or Gasket Kit for JS250
  202. how to start 125d taotao
  203. kandi kd-150gkd-2 wont reverse
  204. Sunl sla-400 timing chain
  205. Won't start!!!
  206. Chinese Kid Quad questions
  207. Starter/starting problems:
  208. Solenoid melted wire
  209. 125cc chain throwing off
  210. Hensim 2007 150 cc Quad GY6
  211. Brand new Peace 110cc ATV makes strange transmission rattle
  212. Engine idles but 'bogs down' under load
  213. vBike 250cc wont start
  214. New guy here , need a little help
  215. Peace sports 125cc hard shift?
  216. Peace sports 110 cc ATV
  217. Kazuma 500 cc jaguar
  218. 125d Won't go Reverse or Drive
  219. tao tao runs but no voltage to regulator
  220. TAOTAO 250 will not crank
  221. chinese 110cc 4 pin cdi intermittent spark
  222. Linhai 260cc has no spark.
  223. help!!!
  224. Daymak 260
  225. Wiring
  226. Dinli 110cc 'Helix'
  227. Kazuma Meerkat 50cc service manual
  228. KL 250 (Zongshen 250) needs wiringdiagram..Lynn!!!!!
  229. Nothing from a Roketa? ATV 110
  230. 110 brake problem
  231. help on a baja 90 atv
  232. Help
  233. 2007 Jetmoto model 150ST-7
  234. 250cc 30 mm carb
  235. New CDI, still won't start ?
  236. Battery draining problem on Eton 90
  237. Kasea KS150
  238. FMH110cc rebuild....
  239. No Spark, Replaced Everything ???
  240. TaoTao ATA125-H Wont Start please Help
  241. TPATV06-150cc
  242. TAOTAO 250 hard to crank
  243. Can someone identify this quad motor type/brand
  244. Only starts when I jump solenoid
  245. 2005 susuki 300cc quad made by National motors
  246. air / fuel mix screw
  247. Hensim 70cc Quad
  248. kazuma dingo 250 problem
  249. 110cc will not fire up
  250. yamoto 150cc tranny problems
