1998 AC454 valve clearance??
Old 06-24-2003, 11:45 PM
Andy Bassham's Avatar
Default 1998 AC454 valve clearance??
Anybody know the valve clearance for a 1998 454 4x4? I have to do the valves on my uncle's bike sometime, and the manual doesn't show what the valve clearance is. Just says "dealer maintenance" by valves.
Old 06-25-2003, 11:15 PM
Bigcat's Avatar
Andy My 2002 shop manual says (cold engine) intake 0.05-0.10 mm (0.002-0.004 in.)
exhaust 0.17-0.22mm (0.007-0.009 in.)
It just reads 500cc and does not give a year they should all be the same anyway
I hope this helps.
Old 06-25-2003, 11:30 PM
TnDuc's Avatar
I hope this helps.
It is the same. I checked my shop manual for my '98 454.
Old 06-26-2003, 09:39 AM
sweet! thanks a lot on that. I figure after I go through the carb, drain out the fuel tank (water leaking through the weak a$$ gas guage- which will be replaced), replace the battery, and possibly install a new float kit, I might as well adjust the valves. Never has been done and this thing has about 1800 miles on it now.
Scooter's Shop
23
10-22-2015 07:04 PM
wrencher82
09-30-2015 04:27 AM
wrencher82
09-28-2015 10:02 PM
2many2ride
09-27-2015 04:35 AM
maveikfe
1) Engine problems..
09-24-2015 10:36 PM
Quick Reply: 1998 AC454 valve clearance??
