1999 arctic cat 300 4x4 wont start - ATVConnection.com ATV Enthusiast Community
LinkBack Thread Tools Search this Thread
Old 01-05-2007, 02:59 AM
Default 1999 arctic cat 300 4x4 wont start
hi everyone,
i am new to the atv forums and i have a problem with my ac i just cant figure out. it wont start. i have good clean spark it is getting fuel and i set the timing tonight but still same problem, i am wondering if it would be a compression issue i am not sure what the compression should be on this atv, and i havent purchased a gauge yet to check it, any help would be greatly appreciated.
thanks
grill
Old 01-05-2007, 04:41 AM
With the throttle wide open (WOT), crank engine 5 to 10 compression strokes. Your numbers should be 157 to 193 PSI.
Old 01-05-2007, 11:23 AM
Check your valve adjustments. What do you mean " you set timing"? When you say it is getting fuel do you mean plug is wet or fuel is getting to carb? If plug is wet have you tried new plug?
Old 01-06-2007, 03:01 PM
i did a compression test last night and i got about 40 to 50psi wot, i assume thats my problem i pulled the head thinking that that a valve would be my problem, they both looked good, but i cleaned them up anyways and put it all back together, i still ended up with the same compression, am i overlooking something with the valves i dodnt think even with bad rings compression could drop that low, and if it is rings is there a good place to buy ac parts from, which piston and ring combo is recommended. and i assume i should have a valve job done while its apart, should i replace the valves and if so what whold i replace them with.
thanks for all of your help,
grill
Old 01-06-2007, 06:05 PM
On that 300 engine, its a known issue of the valves tighten up with use. This leads to a dramatic drop in compression, and shows up as hard starting when cold. You could try bump starting it,...just have another quad pull it with a strap, in gear, until it fires up.
But check the valve clearance...especially the intake valve, and youll probably find no clearance.
Old 01-06-2007, 08:05 PM
That no clearance (if that is the case) is holding the valves partially open, dropping the compression. When you did the compression test, did you do it a second time after pouring a coupla teaspoons in the plug hole? If compession increases you have bad rings if no increase, it is a valve issue.
Old 01-07-2007, 01:55 AM
you guys are awesome, i backed off the intake valve and the compression went to over 150 and then my battery died. so i need to have the valves replaced or just adjusted, and if adjusted how do i do that and what should they be set at.
thanks for all the help,
grill
Old 01-07-2007, 02:40 AM
HR HR is offline
well i'dd say if you got the compressiopn up to 150 then i'dd leave it.. or you can get some feeler gauges and go to town. but with 150 compression. will it start? might be flooded by now.
just my thoughts....
HR.
Old 01-07-2007, 05:25 AM
HR.
I agree with HR, why change the valve when all that is needed is to adjust the clearance. If it won't start with 150psi compression then something else is wrong.
Old 01-07-2007, 12:27 PM
what clearance shoukd the vakves have, and when i got u this morning and cranked it at wot with a new battery in it i hit amost 200 lbs. its amazing what one little adjustment will do.
thanks,
grill
Thread Thread Starter Forum Replies Last Post
Arctic 90 starting issues chinkapin Arctic Cat 6 07-14-2016 07:58 AM
Buying new vs used? neilbedwell Buying an ATV 23 01-18-2016 01:57 PM
98 arctic cat 300 service manuals backhoelover Arctic Cat 2 06-26-2015 01:21 PM
2002 arctic cat tbx 500 4x4 butcho4prez Arctic Cat 3 06-23-2015 10:30 AM
NOS-Atvs - Trail Scouting Extreme (Part 2) 1000gade ATV Videos 0 05-27-2015 01:37 PM
Tags
1999 , 2007 , 300 , 400 , 4x4 , adjust , adjusting , arctic , atv , cat , compress , cranks , start , valves , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
