bleeding rear break procedure
sassee,the newer models do have hydraulic brakes for the foot peddle and surprisingly mine has been working pretty good on my 08 700, but as far as my 02 500, i did as you said and took the brake off completely 6 yrs ago,they're worthless. As far as bleeding it i would think its done the same as any other brake system. Slowly push the peddle while loosening the bleeder screw then tightening it back up before your foot gets to the floor. Repeat till all the air bubbles are out or the fluid stops sputtering. refill the reservoir under the seat(that's where mine is). This is assuming it has a bleeder screw, i have'nt looked.
SixSpeed5
8
08-02-2015 05:38 PM
