Dvx 90
Dvx 90
The Dvx 90 is built by Kymco for Arctic Cat , using approved standard , spec's and quality control ; the manual fit's in a slot on the under side of the seat sealed in plastic to protect it from the element's and shouldn't be that hard to find !..................
Is yours a 2009, with the reverse on it?
BUT she loves it took it out again yesterday and had a blast
Question her front tires dont seem to sit perfectly striaght up and down slight tilt inward
is this normal ?
I would check that out with the dealer, as it seems strange. (Can't look at ours right now, as it is up at the cottage.)
I would think if anything they would tilt out a bit to compensate for the tilting ("squatting") in that occurs with independent suspensions when you put weight on them.
