New temp sensor or just straight wire it ?
Old 07-20-2009, 09:17 PM
S.C.'s Avatar
Default New temp sensor or just straight wire it ?
Just bought an older Cat , 2002 500i auto with around 850 miles on it . Pretty good shape except the guy never washed it after taking it hunting 5 or 6 times a year ! The radiator was about the worst of it all . I had to pull it off to clean it , could not BELIEVE how much mud and muck came out of it !
I'm changing all the shock bushings and replacing the radiator hoses while I have most of the plastic off . Bushings were just about rotten hehehe .
I had found out the fan was not working after about 1/2 mile down the road when the motor sounded like it was trying to run hot . So back to the workshop to see
what was going on and I couldn't believe how much mud was plastered on the back of the fan / radiator !
Well anyway , I've got the radiator and hoses back in but can't remember where the couple of connectors go LoL ! The temp sensor on the bottom of the radiator doesn't seem to be working ....... its not throwing any voltage or ohms ? across the meter . I can hot wire the fan and it comes right on . I have heard of Honda owners amoung others running fans all the time but think that might be a big draw on the battery / charging system ?
Guess I'll have to shell out more $$$ for a new sensor ! Found out the rear brake cable bolt had snapped at the caliper , thats another 55 bucks !!
Anybody have a PDF service manual ? or wiring diagram they would like to share ?
thanks !
S.C.
COFatboy
05-02-2020 12:06 AM
scram5050
08-19-2015 02:19 AM
DeFox500
07-26-2015 06:32 PM
ltrmc02
07-22-2015 04:50 AM
D-Hagz
07-04-2015 02:19 AM
Quick Reply: New temp sensor or just straight wire it ?
