Arctic cat problem
Old 08-23-2009, 06:55 PM
mykmiller's Avatar
Default Arctic cat problem
I have an Arctic Cat 700 EFI and the screen flickers and then everything on it is displayed. It does not go to the normal screen where it shows the hours and mileage. Any ideas?
Old 08-23-2009, 07:23 PM
08700efi's Avatar
did you try unhooking the battery for 30 secs, or unplugging the screen for awhile
Old 08-23-2009, 08:36 PM
mykmiller's Avatar
No I didn't. The battery was dead so I charged it and then it started doing this. I will try disconnecting the battery and if that doesn't work I will disconnect the screen.
Thanks
Old 08-24-2009, 07:23 AM
mykmiller's Avatar
well neither of those fixed it. when it flashes it makes a click noise.
Old 08-24-2009, 08:46 AM
cupsz71's Avatar
For WHATEVER reason, you also have to pull the green 30amp fuse when you disconnect the battery.
I can't be totally sure but it re-sets the gauge but re-setting the ecm internal bkup memory. JUST recharging the battery and disconnecting it briefly doesn't seem to work.
This is a very common issue with the digital gauges on AC's and fairly simple to resolve. My suggestion to you is that if your going to let your quad sit for long periods of time, buy a $20 - 1.5amp battery maintainer and keep your battery charged.
good luck.
my .02¢
Old 08-24-2009, 03:39 PM
Paulram's Avatar
When I got mine recently, the battery was dead and I recharged it. It never held a good charge and the display flickered on and off....
When I replaced the battery, it went away....
Old 08-24-2009, 08:23 PM
mykmiller's Avatar
i may have to replace my battery as none of the aforementioned things are working. the battery isn't the best and probably needs replaced anyways.
Old 08-24-2009, 09:26 PM
mudslinginfool's Avatar
Does it in the Mud!
a friends did the same a week after he bought it and the dealer gave him a new battery and it was fixed.
Nondem
02-22-2020 12:20 PM
ogio117
Polaris Side by Sides
04-29-2019 03:14 PM
Club News and Events
07-23-2015 02:04 AM
hondarider1234
07-21-2015 11:53 PM
Gtsordo
07-13-2015 10:38 PM
Quick Reply: Arctic cat problem
