2" lift kit?
I would stick with what you have, and just enjoy getting more riding experience.
The 26's are just right for what you have. You could go a little taller up to a 27", but taller than that and you will lose a noticable amount of low end power, which you need when you are muddin' about.
You will not lose any handling keeping it at the stock height, but a lift kit or high lift springs will raise the center of gravity, making it harder to keep all four on the ground when you are cornering hard or sidehilling...plus if you are riding with a passenger, you are already dealing with a higher COG (center of gravity) which causes more instability.
Were it me, I would get an exhaust pipe and an air filter and adjust my EFI if needed, and get out and ride
Enjoy your cat!!!!
Enjoy your cat!!!!
I have had 26inch mud lites and High lifter HD springs on my 400 in the past. I use my machine to haul LOTS of big heavy building materials to my remote hunting cabin. I still use the HD springs but currently run 25 inch mud lite tires. I like this setup better as I feel the engine turns the tires much easier and I still have plenty of ground clearance when carrying a heavy load.
Only thing I know lift kits can do is put added stress on bearings and axles. Add to that taller (and heavier) tires and some thing is probably going to break or wear out faster than one would like it to. I am not too sure exactly how much ground clearance you can gain with highlifter springs. But they do make for a much stiffer ride.
As Texas said, you should also look at what type of riding you do the most of and make sure you are not raising the COG too high and messing with the stability of the machine.
If you are looking to just stiffen the ride up more than the adjustments on the shocks allow I would suggest using hockey pucks. Cheap, durable fix that simply pre-loads the pre-load adjustment on the shocks. I have used it now for about 4 years with zero trouble. Cost about $10 and installed in about an hour (with the proper spring compression tools).
Hope this helps
SJ
Hope this helps
SJ
Cantbuytime
08-17-2015 06:33 PM
Cantbuytime
08-16-2015 09:13 PM
MikeyBoyesq
08-10-2015 11:11 AM
