2005 500 Cat clutch?
Old 09-07-2009, 09:08 PM
montyburns's Avatar
Question 2005 500 Cat clutch?
I just bought this machine on Friday. It has more miles than I preferred but the price was decent. (3500 Can.). It came with newer 27" MudBugs and I just love the clearance with these machines as I do a lot of muskeg riding. I noticed that when I take off there is a bit of squeal and a slight hesitation for about half a second and then the clutch engages and takes off. After that no problem with good acceleration. But same thing happens time after time from dead start. I only rode it for a mile or so and I didn't get a chance to look at the condition of the belt or clutch. I've never experienced this before. Well I guess I have when I used to ride my Ski-Doo but not on a quad. Is there any kind of adjustment for this? Thanks Monty
Old 09-08-2009, 02:05 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
sounds like your belt is heat-glazed or worn and is slipping. The 27's don't help the situation.
Take a look at your belt first. They aren't difficult to replace, but replace them with a stock belt, as I have had two friends burn up high-end aftermarket belts and switch back to stocks.
I would also get a clutch kit if I were going to continue to run 27s
salixair
11-03-2015 08:25 AM
Lou Domenech
09-11-2015 06:35 PM
roy.hawkins3@gmail.com
09-11-2015 02:35 PM
Brandon400
09-05-2015 08:44 PM
cdstang
08-31-2015 07:52 AM
Quick Reply: 2005 500 Cat clutch?
