Electrical Problems... HELP!!!!!
2004 650 V2.... ALL STOCK
3 weeks ago i had to reset the belt limit switch (sometimes known as "LIMP MODE") and after i hooked all the wires back up I took it for a couple spins around the house with no problems.....
Now, 3 weeks later, I go out to start it and when i turn the switch... nothing... hmmm well... i thought it was odd but batteries do die so i put in a new one... and turned on the switch and the digital display started blinking and the speed O was reading 7 MPH...I have never see this happen before so i started it up... Fired right up and sounds normal.... but the digital display (all indicators) are flashing and blinking... on and off sporadically... i drive it around the house and it seems to be running OK but the gauges are all messed up....
Did I do something wrong with the jumper reset that would cause a short somewhere?
does this have anything to do with the dead battery (which is relativity new and i was not expecting it to die this soon)???
has anyone see this happen before??????
Sw00p
09-24-2015 02:50 PM
