Arcticcat wont fire
Arcticcat wont fire
I bought a 1996 arctic cat 454 and am having a blast, however..
The last time I used it I drove about 1/4 mile shut off and now have no spark. No warning. Just wont fire. I've heard coil or stator could be cause. Anyone else experience this problem. Also where is stator located. Ive found manuals online but only show magneto assembly. Not where it's located on machine. My 1st experience with atv motors and I'm a little lost.
The magneto assembly is located by your left foot rest if you are sitting on the machine.
The other thing to check before tearing into the magneto is to double check your ignition wiring harness at the base of the steering column. There are a couple of plugs ofr the key and run/off switch that have plus onthe wiring harness at the base of the steering column. If they become pinched and you turnthe handle bars they will unplug all the way or just enough to keep the engine from running. Acts like the run/off swith is in the off position.
Easiest to access if you remove the fuel tank but you should be able to look either under the front fender OR down along the steering column to see the plugs.
If that checks out then I would be tempted to Ohm test the run/off switch to make sure it is not shorted out. These are cheaper to fix and easier to get at.
Swampy
Swampy
Swampy
Swampy
mrtidy
02-03-2016 05:00 PM
IMLN
09-28-2015 03:32 PM
Elkaholic
09-06-2015 02:44 PM
