90 won't start
Old 12-09-2009, 04:09 PM
sand1141's Avatar
Question 90 won't start
I have a 2005 Arctic Cat 90. It cranks over with starter but will not start. I changed the plug and it is firing. It is getting fuel. The rubber gasket in the fuel shut-off switch was breaking down and plugged up the valve. That has been cleaned out, and the carbuerator has been cleaned. Any help?
Old 12-10-2009, 09:35 PM
sand1141's Avatar
Any idea where I might get some help.
Old 12-10-2009, 09:38 PM
lcatv's Avatar
Check the kill switch. It happens to everyone once.
Old 12-10-2009, 09:46 PM
sand1141's Avatar
I have done that in the past, couldn't believe it. The switch is on. Still no go.
Old 12-11-2009, 12:10 AM
**sTiNkfOot**'s Avatar
Not too familiar with AC 90s , but I know other makes have safety checks that prevent starting. Whether it be a kill switch cord triggered, park brake on to start, in neutral to start etc.
New gas? Choke functioning? Air Filter and box clean?
Try starting without air filter?
Old 12-11-2009, 03:25 PM
swampyjunior's Avatar
I would check that it is in neutral and/or pull the brake lever if it has the start in gear feature.
I had the neutral sensor go out and althoug hthe green light was onI could only start it by applying the brake.
Also remember you need fuel, air, spark inthe proper amounts to run.
Swampy
MikeyBoyesq
11-27-2020 02:44 PM
Mkp
03-28-2020 03:50 AM
tiresharkdbb
09-03-2017 02:06 AM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: 90 won't start
