Will parts swap from a 250 4x4 to a 300 4x4
Old 01-01-2010, 09:05 PM
rdeeno's Avatar
Default Will parts swap from a 250 4x4 to a 300 4x4
I have a older, say around a 2000 model 300 4x4 that I got in a swap that is in dire need of some suspension parts. I can get for free a little newer (it has the newer wheels on it) 250 4x4 that has a bad motor or tranny (can't remember). These look close to the same. Will suspension parts and cv shafts swap between these two. Thanks in advance.
Old 01-01-2010, 10:22 PM
Williebee's Avatar
Post from a 250 4x4 to a 300 4x4
What you have is a Suzuki LT4WD 250 QuadRunner ans a Suzuki LT4WD 300 KQ 4x4 engine/tranny and suspenion badged as an Arctic Cat , and they are bullit proff as far as reliabity and longeity goes ; most of the parts are interchangeable ; the engine are basiitly the smae the 300 just has a .10 over cylinder bore and a larger mm size carb giving a few extra CC's .
If the tire and wheel size are the same on both quads you may have something there , my late cousin had both these Suzuki's one was a 1989 Suzuki LT4WD 250 QuadRunner 4x4 and the 1993 Suzuki LT4WD 300 King Quad ; the KQ had larger tires and wheels ( 25x10x12 rear and 25x8x12's front ) the 88' 250 had 25x10x11's and 25x8x11's on front ; you should be able to use most of the part's of either of the two !
williebee.............
Old 01-02-2010, 01:17 PM
rdeeno's Avatar
Thanks. I just picked up the 250. It is a little newer. It was used on a dairy so it was basically a ball of mud and manure when I got it.
toonces
08-12-2015 06:42 AM
austinwhitton
08-11-2015 06:21 PM
toonces
07-28-2015 01:58 PM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Quick Reply: Will parts swap from a 250 4x4 to a 300 4x4
