2009 rear end noise
Same thing many Polaris customers complained about.When you turn left weight shifts to the left compressing the left drive shaft and usually the right plunging joint or cv extends a little and makes a click clacking noise. On Polaris machines the internal knuckle with the ball bearings moves outward. Usually this noise happens as the channels in the plunging joint wear over time. Even had some fairly new ones do this also. Jack up the machine and turn the rear wheel back and forth to see if you have any noticeable play in the joints,plus you can have some walk behind you as you turn slowly to help identify where the noise is coming from. Plus might be a good idea to unclamp the boots to check if enough grease was applied when assembled.
See if this place has what you need.2009-2010 Arctic Cat 550 4X4 Rear Right ATV Axles Back Passenger Side Complete CV | Sixity.com
braap123
09-07-2015 10:57 AM
OutRacing
Technical and How-To Articles
09-03-2015 07:49 AM
