2007 arctic cat 500 fuel problem
Old 08-22-2016, 08:39 PM
geary's Avatar
Default 2007 arctic cat 500 fuel problem
I am not getting gas to the spark plug, the carb is getting gas to the float bowl. I have cleaned the carb and used compressed air to blow out the jets. what do I need to check now? also how do you bench check an ignition coil.
Old 08-23-2016, 03:37 PM
DirtDevil101's Avatar
I like to start by ensuring it's a fuel delivery issue...to test compression/valves and spark I shoot some starting fluid down the plug hole and see if it runs on that...if yes, then we can move on...if no, then you have other issues...
Old 08-23-2016, 10:54 PM
papa hogg scoot's Avatar
Check values may need intake value adjusted...doing an compression check like mention in above will help to tell what next job willbe
murph4478
06-19-2016 01:53 PM
gary45863
Where to Ride
06-06-2016 06:35 PM
tecate1987
06-01-2016 10:01 PM
lil cheese
05-30-2016 07:44 AM
Quick Reply: 2007 arctic cat 500 fuel problem
