650 trv carb problem
My trv has begun to backfire, run poorly, and then
die afterer I have plowed snow for about an hour. Once it does this it won't start till its completly cooled down. Then it'll run fine till its completly warmed up again. gain. I put new gas in it, but that didn't help. Then to check for a heat soak problem I sprayed refrigerant on the coil when was running poorly and about to die. Didn't help. I did the same thing for the ecm with no success. Then I sprayed and cooled the carburetor. This stopped the problem for a few minutes. I repeated the same process multiple times, and it sure seems like its a heat soak problem with the carb. I can't figure out what it would specifically be though. If anyyone's got a suggestion I would sure appreciate it
