700 kingquad stalls sometimes when I turn lights on or when I push the 4 wheel drive.
Old 12-21-2016, 02:56 PM
kenden's Avatar
Default 700 kingquad stalls sometimes when I turn lights on or when I push the 4 wheel drive.
My 2006 700 King Quad stalls sometimes when I turn the lights on or when I push the 4 wheel drive button what could be causing this problem?
Old 12-21-2016, 04:58 PM
hydrex's Avatar
How is your battery? Don't know if it has efi, but low voltage can raise hell with them. Example: I was plowing snow the other day with my Arctic Cat, grip heaters maxed out, headlines on, wideband O2 on, Trail Tech Voyager on etc. After 2 hours, when I hit the winch, the head lights started to flicker... Just saying our tiny charging systems can only do so much.
Old 12-21-2016, 05:37 PM
kenden's Avatar
Default 700 kingquad with efi
It has a brand new battery and I also did the rectifier wiring upgrade.unless battery is bad?? Loose plates or something.
Old 12-26-2016, 06:53 AM
Our editors looked into your question and their answer can be found on the ATV Connection homepage by clicking here:
Ask the Editors: Electrical System Stalls - ATVConnection.com
