Hey KNOWSALOT???????
Old 03-06-2004, 08:15 PM
newguy185's Avatar
Default Hey KNOWSALOT???????
Hey mr. KNOWSALOT i have been refered to you cause every one says you're the atc encyclopedia. If i got a 1982 atc 185s and i want a front fork with shocks, what forks will fit????? Your help would be very appreciated.....
Old 03-07-2004, 12:28 AM
KNOWSALOT's Avatar
The Facility
newguy,
The forks from the 1983 185S and the 1984-1986 200S
There are others that will fit, but the others are built around 25" tires instead of your 22"
No modifications neccessary.
Old 03-08-2004, 03:53 PM
newguy185's Avatar
Thanks for the help KNOWSALOT, you are the atc encyclopedia!!!!!!!!
Old 03-08-2004, 04:00 PM
newguy185's Avatar
could i still use the stock axle and hub with a different fork??????????
Old 03-08-2004, 06:22 PM
KNOWSALOT's Avatar
The Facility
No, the axles and hubs used on the non-suspended forks will not work on the suspended forks.
When you get a set of forks, it's easier to swipe the entire front end rather than pieceing it as you go......so look for one that has everything already there.
Old 03-08-2004, 09:14 PM
newguy185's Avatar
alright thanks man
airtimehocutt
KTM
10
09-14-2002 02:07 AM
DirtDiggler
09-05-2002 12:43 AM
Dirtbadger
07-04-2002 01:33 AM
bobcatv8
06-12-2002 08:17 PM
blaster29
04-08-2002 03:04 PM
Quick Reply: Hey KNOWSALOT???????
